need help fast
Old Jun 27, 2003 | 10:39 PM
thehondaguru's Avatar
Default need help fast
I have been having problems lately with my car hesitating like crazy so I changed all the tune up stuff and no difference. It has almost100,000 miles on it so I thought maybe the valve needed adjustment. So I adjusted the valves and now it has no power at all. No check engine light , at idle its fine and ounce I get up to speed the car runs great. When unbder any kind of aceleration its crap. I mean reallybad. I know I adjusted the valves right but I am thinking my timing was messed uo in the first place and know adjusting the valves made it worse. What u guys think. I really need help and suppod]sed to go to the track on sunday
Old Jun 27, 2003 | 11:03 PM
SIRX's Avatar
Default Re: need help fast (95 lude)
it sounds like you adjusted the valves wrong. Sometimes a hesitating is a fuel problem check your fuel filter. This simple item is often over looked and at 100,000 miles I'm sure it needs to be changed. We change a lot of them at work and this is usually the problem
Old Jun 27, 2003 | 11:08 PM
Default Re: need help fast (SIRX)
I just changed the fuel filter plugs wire al all other easy stuff. I am almost positive I did the valves right. Its pretty easy. I,m not tryiong to sound like an *** if I am
Old Jun 28, 2003 | 12:33 AM
any one else with some info
-Todd-
Oct 14, 2005 06:46 PM
thehondaguru
Jun 28, 2003 12:09 AM
pelotudo
May 3, 2002 08:26 PM
89 CRX SI
Apr 28, 2002 02:16 PM
