will a coupe muffler fit on a hb????
Old Jun 27, 2003 | 04:14 PM
frostt3ch's Avatar
Default will a coupe muffler fit on a hb????
just wonder is a stock axleback will fit on hb? or would it be longer?
Old Jun 27, 2003 | 04:16 PM
frostt3ch's Avatar
Default Re: will a coupe muffler fit on a hb???? (frostt3ch)
umm let me refrase that didnt make sense. just wondering if i got a muffler off of a civic coupe will i be able to bolt it right onto my 95 civic hatchback without any modifications? or will it be a little too long?
Old Jun 27, 2003 | 04:47 PM
Si Arn's Avatar
bolt on a muffler? Are we talking an exhaust system or just a Universal muffler?
Old Jun 27, 2003 | 04:55 PM
2.0L EK's Avatar
Default Re: will a coupe muffler fit on a hb???? (Si Arn)
no it will not "bolt straight up" take it to a muffler shop. Should be cheap less than $50 to get it cut and welded
Old Jun 27, 2003 | 04:59 PM
frostt3ch's Avatar
just talking about a stock axle back
Old Jun 27, 2003 | 05:01 PM
B16b2b's Avatar
Default Re: will a coupe muffler fit on a hb???? (2kTypeRHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kTypeRHatch &raquo;</TD></TR><TR><TD CLASS="quote">no it will not "bolt straight up" take it to a muffler shop. Should be cheap less than $50 to get it cut and welded</TD></TR></TABLE>
if muffler=stock axleback, then....
YES, a 92-95 ex coupe muffler BOLTED straight up to my 96 hatch just fine. be sure to cut a few inches off the tip though. my friend BOLTED up a 99SI muffler to
his 92 hatch. he also cut the tip down. go for it man
it appeared that the only difference between civic mufflers was the tip length. (coupe vs hatch)
Old Jun 27, 2003 | 05:03 PM
frostt3ch's Avatar
thanks for the info guys. it helped me out alot.
Old Jun 27, 2003 | 05:16 PM
B16b2b's Avatar
Default Re: (frostt3ch)
np. good luck. BTW, you can cut the tips shorter with a hacksaw if you want...
chickenwing
Jun 6, 2008 02:16 AM
longalong
Mar 31, 2008 08:07 PM
KRiS1
Oct 13, 2003 09:10 AM
MLogan
May 13, 2003 09:57 AM
