will a coupe muffler fit on a hb????
just wonder is a stock axleback will fit on hb? or would it be longer?
Re: will a coupe muffler fit on a hb???? (frostt3ch)
umm let me refrase that didnt make sense. just wondering if i got a muffler off of a civic coupe will i be able to bolt it right onto my 95 civic hatchback without any modifications? or will it be a little too long?
bolt on a muffler? Are we talking an exhaust system or just a Universal muffler?
Re: will a coupe muffler fit on a hb???? (Si Arn)
no it will not "bolt straight up" take it to a muffler shop. Should be cheap less than $50 to get it cut and welded
just talking about a stock axle back
Re: will a coupe muffler fit on a hb???? (2kTypeRHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kTypeRHatch »</TD></TR><TR><TD CLASS="quote">no it will not "bolt straight up" take it to a muffler shop. Should be cheap less than $50 to get it cut and welded</TD></TR></TABLE>
if muffler=stock axleback, then.... YES, a 92-95 ex coupe muffler BOLTED straight up to my 96 hatch just fine. be sure to cut a few inches off the tip though. my friend BOLTED up a 99SI muffler to his 92 hatch. he also cut the tip down. go for it man https://honda-tech.com/forums/images/smilies/emthup.gif it appeared that the only difference between civic mufflers was the tip length. (coupe vs hatch) |
thanks for the info guys. it helped me out alot.
Re: (frostt3ch)
np. good luck. BTW, you can cut the tips shorter with a hacksaw if you want...
