Upgrades foir Greddy SOHC 15G turbo
Old Jun 27, 2003 | 11:59 AM
KamikazeSol's Avatar
Default Upgrades foir Greddy SOHC 15G turbo
I am thinking about doing a litle work on my new turbo that I got with the Greddy SOHC kit and needed some help. Just wanted to know if anyone knows of any upgrades or rebuilds that can be doen to give it a little more top end and maybe spool up a little faster.
Old Jul 6, 2003 | 08:11 PM
tek_civic's Avatar
Default Re: Upgrades foir Greddy SOHC 15G turbo (KamikazeSol)
i know that a bigger down-pipe will help a fair bit on both counts, does it have a cat? if so then a strieght pipe will help a lot from what i hear. a full 3" turbo exhaust gives better spooling and top end. throttle bodies help a lot more when turbo'd as well as intake mannifolds. get a turbo specific camshaft, that should help a lot. if its not intercooled you should do that first. get a blowoff valve, those help a lot for boost after shifting, and sound cool too. if it were me i would get a throttle body, blowoff, intercooler, and turbo exhaust to start with
Old Jul 6, 2003 | 08:14 PM
TurboJesse
Guest
Posts: n/a
Default Re: Upgrades foir Greddy SOHC 15G turbo (tek_civic)
Id start by having a custom 2.5" dp made
Old Jul 6, 2003 | 08:23 PM
wc's Avatar
wc
If the 16g is drop in replacement for the mitsu, then they should be a drop in for you.
- wei
Old Jul 6, 2003 | 08:40 PM
willyboyK20's Avatar
Default Re: Upgrades foir Greddy SOHC 15G turbo (wc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wc &raquo;</TD></TR><TR><TD CLASS="quote">If the 16g is drop in replacement for the mitsu, then they should be a drop in for you.
- wei</TD></TR></TABLE>
mitsu turbos and greddy turbos are not the same, they don't have the same bolt patterns at the mani.
I would get real engine mangement(hondata, ems) and open up the breathing on the exhaust end.
Old Jul 6, 2003 | 10:39 PM
swrdply400mrelay's Avatar
You can contact forcedperformance.com I think, and they can rebuild the 15G to an 18T compressor, is what they told me before.
Default Re: Upgrades foir Greddy SOHC 15G turbo (swrdply400mrelay)
Or you can ditch the turbo and buy a Garrett T28
Old Jul 9, 2003 | 07:32 PM
Pengo's Avatar
is the t28 bigger? i was always told they were about the same. don't really know tho cuz greddy won't release info on their turbos.
i would stick with getting better fuel management, ic, bov, exhaust, boost controller, and getting it tuned out.
budlightjunkie
Jun 16, 2010 10:07 PM
97civic_coupe
Dec 4, 2008 12:49 PM
175Shot4Door
Jul 17, 2006 08:20 PM
djprettyrick
Jan 12, 2005 09:03 AM
OneFire
Dec 12, 2004 09:18 PM
