ITR 3rd gear grind and slave cylinder noise question...
Old Jun 27, 2003 | 11:11 AM
iperez's Avatar
Default ITR 3rd gear grind and slave cylinder noise question...
Two things... first, am I the only one who "grinds" the gears when I go from 2nd to 3rd on a fast sprint ?? It doesn't happen during normal driving, just when I am accelerating hard.. Is there a fix to this problem ??
Second, I've read a million threads about the squeaking slave clutch cylinder issue. Yes, I know that the recommended fix is to lube the sucker up but the problem comes right back after a couple of days. Can't I just replace the whole slave cylinder and fix the problem permanently ?? What kind of damage can I expect after prolongued use of the car with the squeaky slave clutch cyl ??
Thanks for the help.
Old Jun 27, 2003 | 03:34 PM
Girlzcn2's Avatar
Default Re: ITR 3rd gear grind and slave cylinder noise question... (iperez)
i might be able to helpwith your 3rd gear grind.......gm syncro mesh manual trans fluid.
Old Jun 27, 2003 | 04:04 PM
MackSpeed-616's Avatar
drop the trans, open it and check out the synchronizers
Old Jun 28, 2003 | 05:02 AM
iperez's Avatar
Well, the car is still under warranty. Maybe I should talk to the dealer about the problem.
Old Jun 30, 2003 | 10:15 AM
User 5426's Avatar
That is a perfect example of what happens to my eg with an h22a. Under normal driving it is all good. But if I am sprinting it it will grind in 3rd with the clutch completely pressed. I will try the gm syncro mesh tranny fluid and see if it stops the problem.
Old Jun 30, 2003 | 11:24 AM
bus stop's Avatar
Default Re: ITR 3rd gear grind and slave cylinder noise question... (Girlzcn2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Girlzcn2 &raquo;</TD></TR><TR><TD CLASS="quote">i might be able to helpwith your 3rd gear grind.......gm syncro mesh manual trans fluid.</TD></TR></TABLE>
how much of those GM trans fluid need to add into the tranny......
I'm start grindind the fifth gear after all the track use
Old Jun 30, 2003 | 12:03 PM
baonest1's Avatar
Default Re: ITR 3rd gear grind and slave cylinder noise question... (WhosITR)
well damn. if you are still under warranty, hit up the dealer. if they dont fix it, shoot them, then come ask us.
dont really shoot them tho
Old Jun 30, 2003 | 12:18 PM
iperez's Avatar
Well, I'd still like to shoot the dealer !!! hehe !!
Its just that I know they are going to give me a hard time when I tell them that the problem only happens when I floor it and quick-shift from 2nd to 3rd ... I can already hear the old story about how warranty doesn't cover "race" situations ... Any suggestions as to how I might handle this ??
Old Jul 6, 2003 | 10:38 AM
blackZC (W)
Guest
Posts: n/a
Default Re: (iperez)
race situations? what does the R stand for agin?
Old Jul 6, 2003 | 12:08 PM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">T
What kind of grease are you using? I would suggest some high temp stuff. I doubt replacing the slave would cure the problem. Just lube it. It's seriously so easy to do.
Old Jul 6, 2003 | 01:55 PM
Rob :190:'s Avatar
Default Re: ITR 3rd gear grind and slave cylinder noise question... (Dr Pooface)
head to the dealer. i seriously wish i'd done that a dozen times while my car was under warranty
Old Jul 6, 2003 | 03:10 PM
JiggyKooAndy's Avatar
Default Re: (blackZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackZC &raquo;</TD></TR><TR><TD CLASS="quote">race situations? what does the R stand for agin?</TD></TR></TABLE>
exactly...tell the dealer to shove it.
Old Jul 6, 2003 | 03:23 PM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">Well, I'd still like to shoot the dealer !!! hehe !!
Its just that I know they are going to give me a hard time when I tell them that the problem only happens when I floor it and quick-shift from 2nd to 3rd ... I can already hear the old story about how warranty doesn't cover "race" situations ... Any suggestions as to how I might handle this ??</TD></TR></TABLE>
so whats the point of rev'ing a motor to 8k... ask them why the redline is at 8600. Basicly dealers are lazy. Make sure your ITR is as stock looking as possible.
Just say during spirited driving, like getting on a freeway onramp, shifting from 2nd to 3rd always grinds.
You bitch enough at a dealer you get what you want.
Old Jul 6, 2003 | 03:25 PM
ScaleExtric's Avatar
Default Re: (irev210)
My friend had the same dilemma with his itr 01...2nd to 3rd...they were very cool about it..and fixed it
Old Jul 6, 2003 | 03:44 PM
R you serious's Avatar
that squeak could be the TOB
Old Jul 6, 2003 | 06:08 PM
iperez's Avatar
Well the ITR has been to the dealer a few times and evertime they re-lube the slave cyl it just comes right back after a couple of days. I figure that, since not all 2001 Integras have the problem, then maybe I just got a bad slave cyl... Yeah, I know, but I'm just thinking out loud.
For those who had the "3rd gear grind" problem diagnosed and fixed, can you please say what it was ?? It would really help. Thanks !!
Old Jul 6, 2003 | 06:09 PM
iperez's Avatar
By the way, what's the "TOB" ??
Old Jul 6, 2003 | 06:14 PM
Bob#455's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">For those who had the "3rd gear grind" problem diagnosed and fixed, can you please say what it was ?? It would really help. Thanks !!</TD></TR></TABLE>
My car did the 2-3 grind the first time I tracked it. I changed the tranny fluid not long after, and have done it two times since then. The problem has not come back at all, and I track my car much harder than I used to.
Old Jul 6, 2003 | 08:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iperez &raquo;</TD></TR><TR><TD CLASS="quote">By the way, what's the "TOB" ?? </TD></TR></TABLE> throw out bearing
Old Jul 6, 2003 | 10:24 PM
RexxyR's Avatar
Default Re: (R you serious)
Guys,
I had the exact same problem, changing from 2nd gear to 3rd gear in VTEC would crunch like i wasnt using the clutch.....I told Honda during a service and when i picked it up, they said "we couldnt duplicate the problem", and complained and said that I hadnt asked them to duplicate it but to fix it.......They booked me in for a week later to come in very early and take the mechanic for a drive to show it to him.....well we hopped in the car, went 100mtrs and i wasnt even in vtec and 2nd to 3rd crunched, he just smiled and said "i know exactly what the problem is"....
They ordered the parts and a week later they rebuilt my gearbox......(they did say it was a mess inside.....it was all fixed without any issues, and they looked after me really well.........
they did ask me if i drive the car hard, I just said yes, but within it's limits......always changing under 'redline', i never spin the wheels, i always use the clutch, and the only track drives i have ever done were with the honda club and were sponsored by honda (so were covered.....)
Rexxy
allmotorgsr98
Transmission & Drivetrain
12
Jun 5, 2011 10:25 PM
sipolt89
Dec 10, 2008 02:34 PM
turbo66000
Aug 26, 2008 05:43 AM
Djole_V
Feb 12, 2008 10:12 AM
Hockey27925
Mar 6, 2004 04:26 PM
