transssions problem but no grinds
the ther nite i went ot the track and i missed 3rd gear going down the track, but then banged it back into 3rd. after i trapped i couldnt put it into any gear so i matched the revs and banged it into second at like 25mph without using the clutch. then on the way home my trans would make a really loud winding noise wen i would put it into a lower gear but i would have the clutch pedal depressed. still does it wen the car is cold. could it be a hydoline problem, master cylinder or other problem,or just not enough trans fluid
Re: (Dimi)
hink just changin the trans fluid will help out with the winding noise cuz i jus fig that there wasenough gear oil in the trans case, t by draining it and refilling it will be ok
