To Stroke Or Not To Stroke
Old Jun 27, 2003 | 10:11 AM
B18C_EJ8's Avatar
Default To Stroke Or Not To Stroke
I'm in the process of rebuilding my motor after dropping a valve, and I'm trying to decide on my next course of action.... I definitely want to stay all motor, but want a little more motor, if ya know what I mean... I've heard alot about stroker kits, but I don't know if I want to go that way... I've read lots of posts about good and bad things, but I'm not leaining either way just yet... I'm tired of pumping money into this car, so this will be the last build, so I want long term reliability... Should I just bore it slightly and go with bigger pistons??
My goal is right around 190-200 whp, and I've already got a ported/polished head, with Skunk2 stage 2's in it, and i/h/e...
What do the experts on the All Motor forum think???
Old Jun 27, 2003 | 10:31 AM
beevo.'s Avatar
I'm guessing you have a b18c, if so you don't need to buy a stroker kit they are too expensive IMO. If you want more displacement I would just bore your block 84mm and buy some Darton sleeves. You can still get your goal with the 1.8 liter block.
Old Jun 27, 2003 | 01:12 PM
B18C_EJ8's Avatar
Isn't 84mm awfully big? Or is that why you sleeve it, to maintain the structural integrity??
Old Jun 27, 2003 | 08:10 PM
dfoxengr's Avatar
Default Re: (B18C_EJ8)
u have to sleeve any motor when enlarging the cylinders more that 1mm
Old Jun 27, 2003 | 08:22 PM
J2turbo21's Avatar
Default Re: (hybridvteceg)
Yea i think the max you can go on stock sleeves is 82mm.So if you want a big bore and tougher sleeves then you re-sleeve it.What kind of motor are you trying to build?
Old Jun 27, 2003 | 08:42 PM
10K2HVN's Avatar
Default Re: To Stroke Or Not To Stroke (B18C_EJ8)
it would be nice to tell us what motor you have when your asking our opinion.. ..instead of letting all of us speculate...
but in most cases, its not worth stroking unless you plan to full-out race!
Old Jun 28, 2003 | 07:31 AM
B18C_EJ8's Avatar
Thought my username would tell what motor I'm running, but if not, it's a B18C....
Old Jun 28, 2003 | 08:12 AM
skribblah's Avatar
bend the oil squirters back a little, put some JDM type R pistons on LS rods with ARP rod bolts, all on a LS crank, and with a b16 head with type R camshafts. man that **** would be smokin like crazy.
Old Jun 28, 2003 | 06:48 PM
B18C_EJ8's Avatar
I think I just want to bore it to 84mm, sleeve it, and call it a day... I'm tired of driving the 89 Prelude...
I think that 2.0L with a nice port/polish and Skunk2 stage 2 cams should make a nice combination...
Old Jun 28, 2003 | 06:57 PM
allmtr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
I think that 2.0L with a nice port/polish and Skunk2 stage 2 cams should make a nice combination... </TD></TR></TABLE>
most definately just make sure you got some nice compression
Old Jun 28, 2003 | 07:11 PM
B18C_EJ8's Avatar
I don't think that'll be a problem.. I'll throw some total seal rings on there, Spoon head gasket, and do everything else right this time, and this motor should scream! Can't wait!
Old Jun 28, 2003 | 07:15 PM
B18C_EJ8's Avatar
Another question... I've already upgraded my injectors (didn't go crazy and got 270's) and thought an FMU wouldn't hurt, so picked one of those up, too... Should I really consider upgrading my fuel rail and pump? Or should I be okay with what I've got (stock)??? Thanks for the continued help!
Old Jul 2, 2003 | 09:12 AM
Witty's Avatar
Default Re: (skribblah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">bend the oil squirters back a little, put some JDM type R pistons on LS rods with ARP rod bolts, all on a LS crank, and with a b16 head with type R camshafts. man that **** would be smokin like crazy.</TD></TR></TABLE>
Yeah, smokin like crazy. As in 3 quarts of oil every 500 miles.
Old Jul 2, 2003 | 11:33 PM
10K2HVN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Witty &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, smokin like crazy. As in 3 quarts of oil every 500 miles.</TD></TR></TABLE>
lol..!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I don't think that'll be a problem.. I'll throw some total seal rings on there, Spoon head gasket, and do everything else right this time, and this motor should scream! Can't wait!</TD></TR></TABLE>
i dont know from personal experance, but word on the street is that "Total Crap (Total Seal)" Piston Rings Suck........
turbohatch96y7
Feb 21, 2013 09:16 AM
excoupeb20jdm
Honda CR-V & Element
Feb 1, 2013 08:32 AM
92civicman
10
Feb 3, 2005 03:42 PM
mugen99
Jun 19, 2004 10:08 PM
es four
Dec 5, 2002 09:05 AM
