sucking air thru the breather in the valve cover?
Old Jun 26, 2003 | 10:55 PM
Ivan's Avatar
senior gold member
Default sucking air thru the breather in the valve cover?
ever since I built my ls/vtec I've been getting this problem. air is getting sucked in thru the breather on the valve cover. The car runs fine and I've done compression tests and what not. Why is it doing that? PCV system is hooked up and everything. the setup is ctr pistons and type r cams.
Old Jun 26, 2003 | 11:46 PM
Beave0101's Avatar
Default Re: sucking air thru the breather in the valve cover? (Ivan)
air is getting sucked in...from the intake? if you check out your helms manual....air is supposed to go in through there.....
Old Jun 26, 2003 | 11:51 PM
Ivan's Avatar
senior gold member
Default Re: sucking air thru the breather in the valve cover? (Beave0101)
on the inlet to the valve cover. its sucking air into the valve cover instead of blowing it into the air intake. the way the arrow is pointing is the way air is getting sucked in. its not sucking in much but none the less it should be blowing and not sucking.
Modified by Ivan at 3:43 AM 6/27/2003
Old Jun 27, 2003 | 03:30 AM
b19coupe's Avatar
What is the problem? If your PCV system is hooked up, there should be vacuum present in the crankcase (and the valve cover) at idle. When you are in the throttle, and manifold vacuum is low, the high speed air going through the intake is supposed to draw excess crankcase pressure (and blow-by gasses) through the valve cover, from the very port that you have circled in the picture. The blow-by is routed to the intake manifold for burning in the combustion chamber.
Old Jun 27, 2003 | 04:37 AM
Suprdave's Avatar
Default Re: sucking air thru the breather in the valve cover? (b19coupe)
You need a slash cut tube...Ill show you how.
Suprdave
dannyly17
Jan 14, 2011 08:20 AM
italiano23q
11
Feb 8, 2006 05:44 PM
SETI20
May 9, 2004 03:23 AM
Ivan
Jun 27, 2003 07:25 AM
fred92htch
Sep 9, 2002 04:24 PM
