HELP.....12mm Air Breather Valve Cover Filter.
can any1 tell me wat a Air Breather Valve Cover Filter does got 1 at home but dnt no wat its for. is it worth putting it on
you put it on your valve cover to vent pressure.
its used in conjunction with PCV system modifications.
please learn to type, i had to reread your post about 6x to understand what the hell you were asking.
any1 = anyone
wat = what
dnt = dont
no = know
any1 = anyone
wat = what
dnt = dont
no = know
Risky Business
Re: HELP.....12mm Air Breather Valve Cover Filter. (italiano23q)
You attach it to the valve cover so that the crankcase gases vent into the atmosphere instead of being recirculated into the intake. In my opinion, they are completely worthless unless you are running a turbo setup (in which case the boost from the turbocharger would leak back into the crankcase and cause huge problems) or if you're running a catchcan setup and you need to vent the gases going into the catchcan. I'm sure both of those explanations are completely out of your realm of understanding, so the best use for you would be to put it on your nose and pretend you have a K&N intake breathing apparatus.
this may help you understand how pcv works, unless your boosted i wouldnt touch anything
https://honda-tech.com/zerothread?id=1490117
Risky Business
Re: (turbotime)
The valve cover "breather" has nothing do to with the PCV system!!! Yes it deals with crankcase gas emissions, but its got nothing to do with the PCV valve/charcoal canister below the IM.
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">The valve cover "breather" has nothing do to with the PCV system!!! Yes it deals with crankcase gas emissions, but its got nothing to do with the PCV valve/charcoal canister below the IM.</TD></TR></TABLE>
Sure it does, it lets in fresh filtered air for when the pcv valve is operating.
Risky Business
Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
Sure it does, it lets in fresh filtered air for when the pcv valve is operating.</TD></TR></TABLE>
I retract my statement then.
Re: (kaoss_11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 »</TD></TR><TR><TD CLASS="quote">So why bother putting a filter on the valve cover? </TD></TR></TABLE>
To keep dirt out?
To keep dirt out?
Corinthians
12-17-2004 07:08 AM
