Is there any way to make a cel go out while running a "test pipe"?
Old Jun 26, 2003 | 04:22 PM
ninety9ex's Avatar
Default Is there any way to make a cel go out while running a "test pipe"?
Just like it says, "Is there any way to make a cel go out while running a "test pipe"?" It pops a "Catalyst system Efficiency Below Threshold" (Code 70).... Is there anyway to make it go out without putting the "cat" back on?
Old Jun 26, 2003 | 06:36 PM
D0HC's Avatar
Default Re: Is there any way to make a cel go out while running a "test pipe"? (ninety3EX)
Yes try a search You could use a 02 sim or try the tin foil trick!
edit: Are you using an OBD1 set up?
Old Jun 27, 2003 | 01:23 PM
ninety9ex's Avatar
No OBD1 set-up
Old Jun 27, 2003 | 04:23 PM
GetawayInMoscow's Avatar
Try wrapping your second o2 sensor in tin foil. Thats what I've read about jeep guys doing
kantfadedisazn
Aug 3, 2009 10:00 AM
LunchboxZT
Feb 9, 2007 02:09 PM
typesguy
Jul 22, 2004 02:08 PM
kool168
Jan 23, 2004 08:27 PM
Hybrid 350GT
Mar 6, 2003 09:44 PM
