My setup, opinions please before I install it
This will all be going on a d16y7
JRSC @8psi
hondata s100 w/boost
p06 ecu chipped and OBDII-OBDI harness
440cc injectors with clips
gauges - boost, egt, fuel pressure
opinions please. Also, I'm almost at 30k miles, what should I throw in there for new spark plugs? Thanks,
-Pfieff
JRSC @8psi
-Pfieff
wouldnt you need a higher output fuel pump like a Walbro 255 for the 440 injectors?
OMG I am so stupid!!!!!!! Ah haa haa haa, I didnt even freaking read that part.....sorry!!!!
no, u dont need a turbo timer. get a set of colder spark plugs like denso iridium, make sure u have motor oil if your gonna do the install your self, change your air filter or clean (depends on what u got). i might be wrong but i think u dont need the p06 since your gonna have hondata.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmaxturbochic »</TD></TR><TR><TD CLASS="quote">wouldnt you need a higher output fuel pump like a Walbro 255 for the 440 injectors?
OMG I am so stupid!!!!!!! Ah haa haa haa, I didnt even freaking read that part.....sorry!!!!</TD></TR></TABLE>
your right he does need a stronger feul pump like a walbro 255 should be cool, unless i am tottally retarded and dont see sumthin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romeo619romeo »</TD></TR><TR><TD CLASS="quote">you dont need the fuel pump im sure the stoc fuelpump will supply the injectors just rite... i say.. get some nology's for wires...i say save up for watercool set up</TD></TR></TABLE>
Use stock wires, there is no sense in upgrading the wires unless they are worn, honda factory wires have been PROVEN many times to be the best wires. Do a search on plug wires and you'll see. Actual tests have been done.
nota-eg
Jun 17, 2005 07:40 AM
