My setup, opinions please before I install it
Old Jun 26, 2003 | 10:59 AM
Pfieff's Avatar
Default My setup, opinions please before I install it
This will all be going on a d16y7
JRSC @8psi
hondata s100 w/boost
p06 ecu chipped and OBDII-OBDI harness
440cc injectors with clips
gauges - boost, egt, fuel pressure
opinions please. Also, I'm almost at 30k miles, what should I throw in there for new spark plugs? Thanks,
-Pfieff
Old Jun 26, 2003 | 11:04 AM
turbochic's Avatar
Default Re: My setup, opinions please before I install it (Pfieffdog)
wouldnt you need a higher output fuel pump like a Walbro 255 for the 440 injectors?
OMG I am so stupid!!!!!!! Ah haa haa haa, I didnt even freaking read that part.....sorry!!!!
Old Jun 26, 2003 | 11:06 AM
Pfieff's Avatar
turbo timer for a supercharger?
Old Jun 26, 2003 | 11:25 AM
Gr8Wyt3's Avatar
Default Re: (Pfieffdog)
no, u dont need a turbo timer. get a set of colder spark plugs like denso iridium, make sure u have motor oil if your gonna do the install your self, change your air filter or clean (depends on what u got). i might be wrong but i think u dont need the p06 since your gonna have hondata.
Old Jun 26, 2003 | 11:27 AM
Gr8Wyt3's Avatar
Default Re: My setup, opinions please before I install it (fmaxturbochic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmaxturbochic &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt you need a higher output fuel pump like a Walbro 255 for the 440 injectors?
OMG I am so stupid!!!!!!! Ah haa haa haa, I didnt even freaking read that part.....sorry!!!!</TD></TR></TABLE>
your right he does need a stronger feul pump like a walbro 255 should be cool, unless i am tottally retarded and dont see sumthin
Old Jun 26, 2003 | 11:28 AM
Pfieff's Avatar
I need the p06 because I need an OBDI ecu and that is the OBDI that works best with my car. I thiink I am going to switch to some mobil one when I do the swap.
Old Jun 26, 2003 | 11:31 AM
Pfieff's Avatar
about the fuel pump, people are telling me that the stock one is good up to 250whp, no?
Old Jun 26, 2003 | 01:20 PM
Pfieff's Avatar
Old Jun 26, 2003 | 01:29 PM
romeo619romeo's Avatar
you dont need the fuel pump im sure the stoc fuelpump will supply the injectors just rite... i say.. get some nology's for wires...i say save up for watercool set up
Old Jun 26, 2003 | 01:52 PM
Neukin's Avatar
Default Re: (romeo619romeo)
ID GET A NICE HEADER/EXHAUST TOO IF YOU DONT HAVE THEM ALREADY.
Old Jun 27, 2003 | 05:53 AM
Pfieff's Avatar
toyosupr, how do you like your kamikaze headers? That is what I was thinking about going with? Any other opinions on the setup?
Old Jun 27, 2003 | 02:35 PM
Neukin's Avatar
they are awsome headers... the best you can get when it comes to matching it up with the jrsc.
Old Jun 27, 2003 | 04:02 PM
Pfieff's Avatar
did you get the ones with the 2.5" outlet or just the regular ones?
Old Jun 27, 2003 | 05:51 PM
Neukin's Avatar
it was with the 2.5 inch outlet
Old Jun 27, 2003 | 06:01 PM
bluebullet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romeo619romeo &raquo;</TD></TR><TR><TD CLASS="quote">you dont need the fuel pump im sure the stoc fuelpump will supply the injectors just rite... i say.. get some nology's for wires...i say save up for watercool set up</TD></TR></TABLE>
Use stock wires, there is no sense in upgrading the wires unless they are worn, honda factory wires have been PROVEN many times to be the best wires. Do a search on plug wires and you'll see. Actual tests have been done.
nota-eg
Jun 17, 2005 07:40 AM
97dc2
May 30, 2005 10:30 PM
nato76
Apr 16, 2004 12:52 PM
redboost10
Dec 3, 2003 06:17 PM
smoothludey2
Oct 1, 2001 03:27 PM
