what fans to use with fluidyne rad.
Old Jun 26, 2003 | 08:08 AM
95gsr's Avatar
Default what fans to use with fluidyne rad.
ever since i installeded my fluidyne I lost the ac fan. and i noticed that when I lost the fan my ac is not as cold as it was. Is there a way to get another fan like a fal or some sort to get my ac fan back. thanks
Luis oh this is for a 95 gsr
Old Jun 26, 2003 | 08:10 AM
hi mom's Avatar
Default Re: what fans to use with fluidyne rad. (95gsr)
I think Fluidyne sells a brand that you can attach to the rad itself, but in my case, I just used some welding equipment, welded some brackets aand put my stock fan on the rad. Never had air that cold in my life, took about 5 minutes to make the brackets, and for never welding, it looks like Fluidyne did it, I cant take some pics if you want..
Old Jun 26, 2003 | 08:20 AM
95gsr's Avatar
Default Re: what fans to use with fluidyne rad. (Teg2Slow)
could you please my ac turned really warm after that install
thanks
Old Jun 26, 2003 | 09:06 AM
hi mom's Avatar
I don't know how well these pics turned out, so lets hope it helps..
^ you can see the weld spots where I mounted the old AC fan.. I made a little clip thats the shape of an L to hold the bottom on aswell..
^ both fans running, also shows you that they fit perfetly along the back of the rad..
Old Jun 26, 2003 | 10:56 AM
95gsr's Avatar
you used aluminum for the brackets? how hard was it to weld. ps never weld before in my life. thanks for the pics Luis
Old Jun 26, 2003 | 02:00 PM
hi mom's Avatar
Yeah, you could probably take it to any metal shop and get them to weld it for 15-20 bucks, its easy..
Old Jun 26, 2003 | 02:09 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yeah you won't get cold air w/o the fan. When we were at NOPI last year (my car and my friend's Civic both inside the speedway), somehow the screw came out of the A/C fan on my friend's Civic, so he had no cold air. I busted out my handy tap and die set and re-tapped the hole in the fan blades so that I could use a screw I had laying around in my toolbox, and voila! he had cold air once again.
Old Jun 26, 2003 | 03:16 PM
VTECPWR's Avatar
Default Re: what fans to use with fluidyne rad. (PatrickGSR94)
If you have a newer teg you never have had very cold air. I have a '98 GSR and have to say it is the worst A/C I have had. BeCool also makes some adjustable fan brackets that will work, no welding required.
Old Jun 26, 2003 | 03:48 PM
95gsr's Avatar
Default Re: what fans to use with fluidyne rad. (VTECPWR)
can i just go to some auto parts store and get some brakets you think
Old Jun 26, 2003 | 04:08 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECPWR &raquo;</TD></TR><TR><TD CLASS="quote">If you have a newer teg you never have had very cold air. I have a '98 GSR and have to say it is the worst A/C I have had. BeCool also makes some adjustable fan brackets that will work, no welding required.</TD></TR></TABLE>
Why is that? My 94 uses R134a and the A/C is pretty darn cold, 140K miles on the car and engine as well. Are newer ones less effective?
Old Jun 26, 2003 | 05:04 PM
hi mom's Avatar
Yeah, I have a 95 LS and with the Fluidyne rad I can chizel my ball hairs off.. its really cold (excuse my french)..
Old Jun 26, 2003 | 05:20 PM
95gsr's Avatar
i went to the local auto supply store and they don't sell any uni brackets I might just buy the fluidyne fan with the brackets what you guys think and where would be a good place to buy.
Old Jun 26, 2003 | 05:42 PM
jdmotorsports's Avatar
FAL makes a dual fan thats realy thin. it fits perfectly.
Old Jun 26, 2003 | 05:45 PM
hi mom's Avatar
Default Re: what fans to use with fluidyne rad. (jdmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">FAL makes a dual fan thats realy thin. it fits perfectly.</TD></TR></TABLE>
I vouch for that, great brand aswell.. but can be pricey!! but your buying a fluidyne rad, go big or go home and weld like I did haha
Old Jun 27, 2003 | 05:18 AM
95gsr's Avatar
I found this on the web site but I can't find a price I'll give them a call later on today and inform you all
Old Jun 27, 2003 | 12:34 PM
95gsr's Avatar
holy **** nopi has them for 400$$$
Old Jun 27, 2003 | 01:43 PM
pr0jektdc2's Avatar
okae sorry if im going off topic but i replaced my radiator about 3 months ago and ever since i/ve only seen one fan work and only when my AC is on [the one closest to the passenger side] i dont remember if the other side [drivers side] has turned on but i havent seen it turn on since...are both suppose to be on at once or is this normal!?!?
Old Jun 27, 2003 | 02:07 PM
hi mom's Avatar
Default Re: (pr0jektdc2)
mine did that too, then I changed the fuses and they both started working!
duyfash0
Oct 8, 2008 06:46 PM
oMek
Jul 6, 2006 04:38 AM
jazz215
17
Jul 27, 2003 05:17 PM
Marcos
Apr 13, 2003 09:24 AM
