CTR cams vs. skunk2 stage I
definately go with the CTR cams over the stage 1's. they make roughly the same power( dyno tuned of course), and you can get the ctr's for almost half of what you will pay for the stage 1's. and no you do not need to upgrade the valvetrain unless you plan on raising the rev limmiter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenDC2 »</TD></TR><TR><TD CLASS="quote">they make around the same power.</TD></TR></TABLE>
I'll have to disagree with you.
if you can find the stage 1 about the same price as ctr then get the stage 1, if not ctr is fine. the reason i got the stage 1 because my friend sold it to me cheap.
about the same power.....i feel the stage 1 give little more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid ctr »</TD></TR><TR><TD CLASS="quote">
I'll have to disagree with you.</TD></TR></TABLE>
does anyone have anything to back this up? dyno charts or something.
I believe that last time I was at the skunk site they displayed dyno charts, but I haven't seen performance charts on the CTR cams.
CTR cams are great, but Skunk2 Stage 1's are more agressive and give better gains. Especially if you build your motor even more. Skunk2 cams love compression as well.
I've seen Dyno charts where Stage 1's gave as much as 10wHP+ more over the ITR cams.
Do a search and you'll see tons of threads that are similar to this.
If you plan to boost your car in the future, I'd go with CTR cams, but if you are planning to go All Motor, then Skunk2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Tech »</TD></TR><TR><TD CLASS="quote">CTR cams are great, but Skunk2 Stage 1's are more agressive and give better gains. Especially if you build your motor even more. Skunk2 cams love compression as well.
after i went over all the replies, i decided to get skunk2 stage1 with skunk2 cam gears as well. hope they both along with current mods will give me at least 200 whp. thanks guys.
</TD></TR></TABLE>after i went over all the replies, i decided to get skunk2 stage1 with skunk2 cam gears as well. hope they both along with current mods will give me at least 200 whp. thanks guys.
Good Luck to you man.. i'm still trying to decide what to get for my car from these too.. i think i'm going to end up going with the CTR ones.... i been hearing too many bad storys about the Skunk 2s breaking, rather have a little less power, but make my motor last longer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid ctr »</TD></TR><TR><TD CLASS="quote">Skunk2 Stage 1's
you can use stock springs and retainers (assuming you have an ITR or ITR valvetrain)</TD></TR></TABLE> and then you can push out an amazing 160 whp like some idiot on this board. CTR cams will give you around the same gains. look @ my dyno chart for evidence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 »</TD></TR><TR><TD CLASS="quote"> and then you can push out an amazing 160 whp like some idiot on this board. CTR cams will give you around the same gains. look @ my dyno chart for evidence. </TD></TR></TABLE>
lol..i believe that was 161! with a gain of 2 hp from his base run and a loss of 7 tq from base run..!
https://honda-tech.com/zerothread?id=485024
Skunks Stg 1's are bigger then CTR's and with the right tuning, in the end, youll be able to make more then the CTR's with skunk 1's...
There's a higher possibility that things can go wrong with aftermarket products but there's also a higher possibility to make more power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10K2HVN »</TD></TR><TR><TD CLASS="quote">
There's a higher possibility that things can go wrong with aftermarket products but there's also a higher possibility to make more power.</TD></TR></TABLE>
Rather have reliable cams than to risk my motor on just a lil more power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon »</TD></TR><TR><TD CLASS="quote">
Rather have reliable cams than to risk my motor on just a lil more power.</TD></TR></TABLE>
then dont mod your car at all.
this doesnt just apply to Skunk cams.. it applys to every aftermarket mod you do to your car... Skunk cams have been proven to be a very good quality. Sure, they have broke a couple..but can your really blame them when some people break ITR, CTR, HONDA STOCK CAMS!!! EVERY CAM MANUFACTURE HAS HAD SOME BROKEN CAMS! EVEN OEM MAKERS (<most likely because of bad installers).
Yep, most of the time it's because of a bad install. But not once have i heard about or seen a CTR cam break. Maybe there are some people had problems with them, but from what i seen on this board is junk2 breaking or having more problems with junk2 cams.
I was going to get the junk2 cams but for some reason i have a bad feeling about me getting them, so I'm just going to go with the CTR cams. Just knowing that it's OEM; makes me feel good.
Death from Above
69
May 5, 2004 08:10 AM
