So who else is gonna try the STi/Evo I/C water sprayer? maybe a CO2 shot?
I have an EG...i just got a CF duckbill, and i ripped out my rear window sprayer thing...and then i thought, hey, i can use this to squirt water at my IC! then i was like, well i wonder how much STi or EVO sprayers are anyway, cuz i bet the spray patter from those jets are better than this sprayer...and im not even sure my washer thing works anyway
so i posted on a subaru board and someone sent me to http://www.rallispec.com
and under the turbo/intercooling section, i saw this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
STi Water Spray Components
RST-8300 Ver.7 STi Manual Water Spray Switch -- $29
RST-8301 Ver.4/5/6 STi Manual Water Spray Switch -- $23
This is a momentary on type switch for providing water spray as needed during heat soak conditions. Uses same style connector as cruise and fog lamp switches.
RST-8303 Ver.7 STi Automatic Water Spray Switch -- $29
RST-8304 Ver.4/5/6 STi Automatic Water Spray Switch -- $23
This is an on-off type switch with indicator light for "on" position. For use as an arming switch in a boost or temperature activated automatic water spray system. Uses same style connector as cruise and fog lamp switches.
RST-8785 STi Water Spray Nozzle -- $10
Dispenses a fine mist of liquid in a fan shaped pattern over the intercooler core.
RST-8780 Ver.7 STi RA Spec C Water Spray Tank Kit -- $147
RST-8781 Ver.7 Washer Tank w/ 2nd Pump for Water Spray -- $85
We offer two water spray tank options. The first, from the Spec C, is a large 12L tank that bolts to the vertical supports behind the back seat (in the trunk). The second more economical options is the factory windshield washer tank that uses a second pump to feed the water spray system.
so the sprayer itself is 10 bux...now, I can just source another windshield washer pump and a spare container to hold water right? pack that bitch full of ice
and this should work...
i was also thinking of buying a nitrous purge valve and mounting it to spray CO2 in the same direction as the water...to "freeze" the water on the IC ....
any comments on this?
and this should work...i was also thinking of buying a nitrous purge valve and mounting it to spray CO2 in the same direction as the water...to "freeze" the water on the IC ....
hm i should check the sprayer on my friends scooby. i can't believe i didnt even think of that, good thinking
. that $10 sprayer will most definitely spray better than the stock **** most cars have. too bad my windshield washer resevoir and pump were already pulled out a long time ago...i woulda just used those.
JDMCRX
Sep 16, 2003 12:05 PM
