Code 15 Problem ?
Old Jun 25, 2003 | 03:08 PM
CiViC SiR's Avatar
Default Code 15 Problem ?
I have code 15 (Ignition Output Signal)
missing or defective ignition output signal
what should i check?
Old Jun 26, 2003 | 06:56 AM
JimBlake's Avatar
Default Re: Code 15 Problem ? (CiViC SiR)
12v power to the distributor?
Distributor itself?
Ignitor?
Got spark? If so, then the stuff above is OK.
distributor wiring harness?
wires from there back to the ECM?
Old Jun 26, 2003 | 07:07 AM
Patch's Avatar
Default Re: Code 15 Problem ? (JimBlake)
Jim is right on all of his suggestions. Code 15 is a bitch to track down. Are you having any starting/driving problems? I would check:
1. 12v to distributor (should be black wire)
2. Resistance in coil
3. Test the igniter
4. Test the - wire off the distributor (ECU ground) for continuity
Ct93CB7
Oct 21, 2010 09:26 AM
v8hnta
Jul 13, 2006 11:21 AM
93slmdcvcsi
Aug 27, 2004 09:53 AM
Sobe_Death
Mar 11, 2004 10:09 AM
CiViC SiR
Jun 25, 2003 03:59 PM
