Code 9
Old Oct 19, 2010 | 07:44 PM
Ct93CB7's Avatar
Default Code 9
so my car is runnig like **** and i checked for codes and i have a code 9 which is the CYP sensor.... has neone else had this prob?????
Old Oct 19, 2010 | 08:39 PM
HonBeer's Avatar
Default Re: Code 9
Nobody has ever had that problem. Congrads your the first one ever!
Old Oct 19, 2010 | 10:44 PM
brakedrum's Avatar
Default Re: Code 9
I've seen it years ago. Turned out I had broken the white wire on one of the plugs that goes from car wiring harness to the distributor while trying to seperate two stuck plugs. I had to do some quick and fast soldering or I was facing replacing all or some of the my Honda's wiring harness. If your wires are undammaged and firmly plugged in, suspect your distributor. If it is a cheaply-priced, aftermarket distributor, suspect it even stronger.
Old Oct 20, 2010 | 06:10 AM
Ct93CB7's Avatar
Default Re: Code 9
ok ill check it out.... honbeer very funny!
Old Oct 21, 2010 | 09:26 AM
brakedrum's Avatar
Default Re: Code 9
You're actually lucky. Your code points to a very specific magnet in the distributor that has only one job to do; identify the first cylider in the firing order over and over and over. Repair that (rare) or replace the distributor (common) and the Code 9, the engine miss are gone. The fun codes are ones like 43, which could point to any of a number of different parts.
SkIp_Civic_Ek6
Nov 27, 2019 10:08 AM
cornfed
Engine Management and Tuning
Jan 27, 2012 02:49 AM
extensioncordy
10
Oct 30, 2006 07:21 AM
GuyInASpeedo
Sep 25, 2003 07:05 PM
xci_ed6
Feb 28, 2003 03:01 PM
