Blowing smoke..
Old Jun 25, 2003 | 02:33 PM
bew
Guest
Posts: n/a
Default Blowing smoke..
Hrm, so today (as usual) I notice smoke coming from my exhaust at high rpms. I just noticed it at idle 2 weeks ago, btw. I'm sure the piston rings are part of the cause, but I was confused about something.
When I got home this morning, I had someone rev my car so I could watch the smoke color. It first came out somewhat white, then went to blue and almost looked like it changed to black as the idles went back down. There's 3 colors (if it wasnt just my eyes) so I'm curious as to what it may be. There's no mily substance in the oil, and no smoke anywhere else. The plugs are a light grey color.
For reference, it's an LS/VTEC setup. I know the car needs some serious tuning as it's not making the power it should be. But recently (I think 2 days ago) I noticed it feeling VERRRY sluggish between 6k-7.2k rpms. It's like there's nothing there after 6k, then around 7000 BAM.. typical vtec beast awakens.
I'm using a V-AFC with no fuel settings, just sensor/car type and other nessicary options set. I am also using a "raw" chipped p28 ECU.
Old Jun 25, 2003 | 02:40 PM
Paranoid Android's Avatar
Default Re: Blowing smoke.. (bew)
Bluish-Grey: Rings or valve seals (most likely rings)
White: Coolant
Black: Fuel
Hope this helps.
Edit- Heh, sorry I didn't read your whole post.
So you say you have all three colors? You had them exactly right, so I guess you did see them.
How many miles do you have on the engine? Could the valvetrain be bad? Check all fuel lines for small leaks. Check headgasket and oil pan.
Hope this helps.
Old Jun 26, 2003 | 01:32 AM
bew
Guest
Posts: n/a
Default Re: Blowing smoke.. (Paranoid Android)
The motor only has around 8k miles on it.
Old Jun 26, 2003 | 08:59 AM
Black-Stang's Avatar
DO you have a high flow catback that could be the problem. I have a MAC X pipe off road in to a flowmaster catback and when i hit it hard it will smoke. and if it feel's sluggesh you may need a tune up. Or may be you have loss some back pressure from your exhaust.
Old Jun 27, 2003 | 05:35 AM
bew
Guest
Posts: n/a
Default Re: Blowing smoke.. (Black-Stang)
Well, right now I have a 2" testpipe going to a 2.25" cat-back exhaust. I know it's bottlenecked, but thats the setup how I bought it so I installed what I had. As of now, I notice that it feels like vtec is NOT kicking in. Yet my vafc shows it as engaging. I hate cars now.
Old Jun 28, 2003 | 11:15 AM
Man, maybe you just need to adjust your valves.
Mr_Flemz
Jun 28, 2007 12:51 PM
93b18civic
16
Oct 11, 2002 05:16 AM
RedGSRblingin
May 23, 2002 06:48 PM
PMTypeR
May 21, 2002 07:15 PM
ALF
Jun 26, 2001 05:17 AM
