warped head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_SeaBass »</TD></TR><TR><TD CLASS="quote">Where would I find another head for a B16a?
it will be a lot cheaper and easier just to go mill the head down.
i have a "vx" head w/ gaskets ... motor is d15 outta a 91 lx. is this a straight bolt on ?? or will i have distributor problems ? i know i need to do the mpi conversion correct ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efracer »</TD></TR><TR><TD CLASS="quote">i have a "vx" head w/ gaskets ... motor is d15 outta a 91 lx. is this a straight bolt on ?? or will i have distributor problems ? i know i need to do the mpi conversion correct ? </TD></TR></TABLE>
yes you will have to do mpfi, and also the vx motor is also obd1 not odb0 like our cars are, im sure you can modify a 1.6 liter obd0 dizzy to work with the vx head but then you have to worry about the obd1 injectors and ****. again more of a pain in the *** if you want to keep your 1.5 stock
92hatchdude
Nov 10, 2003 09:10 AM
