bad vibration after swap
Old Jun 25, 2003 | 11:17 AM
untitled's Avatar
Default bad vibration after swap
there is fluid on the inside of the FR wheel. i cant figure out if it is tranny fluid or brake fluid. between 10 and 45mph there is a vibration. the vibration worsens as speed increases. when i turn left and right the vibration seems to stop. also when i give the car a liittle gas, it squeaks from the FR. the FR wheel is where the fluid id at too. could it be possibly tranny fluid that ran out is causeing the squeaks and vibration?
Old Jun 25, 2003 | 11:44 AM
untitled's Avatar
Default Re: bad vibration after swap (88crx91integra)
cmon guys. help.
Old Jun 25, 2003 | 12:36 PM
Paranoid Android's Avatar
Cv joints, bad axles.
I'm about 99.8% positive.
Moderator of eg civic+del sol forum made a write up on how to change your axles in 30 minutes.
His account is b18c5-eh2 if you wanna pm him.
Old Jun 25, 2003 | 01:23 PM
untitled's Avatar
anyone else
Old Jun 25, 2003 | 02:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">anyone else</TD></TR></TABLE>
Did you read my post?
99.8%
Pm B18c5-eh2. I'm not wrong.
Old Jun 25, 2003 | 02:47 PM
untitled's Avatar
Default Re: bad vibration after swap (Paranoid Android)
i like alot of input. you could no your stuff and maybe you dont. not flaming. any way my front rotor is all grooved up so thats why. also the brakes are acting weird. its like i have to pump them to get pressure. so maybe brakes?
Old Jun 25, 2003 | 02:58 PM
Ok.
Brakes: No
Rotors: Yes
No offense or something but I didn't figure you would ask about something so obvious.
If you have warped rotors then definitely replace those before you look into axles or cv joints.
EDIT- Also, your question about pumping the brakes. It's not your breaks that are causing the vibration. The reason your brakes need pumping, is because there is air in the lines. You need to bleed your brakes. This can prove to be a frustrating process unless you have a friend.
Edit-I take that back, with one of these: you can do it seemingly easy by yourself.
You can pick up one of these 'SpeedBleeders' in the Best Buys forum for 5 dollars.
Old Jun 25, 2003 | 03:12 PM
untitled's Avatar
hey thanx man. but about the brakes, they didnt squeak or cause vibration or anything before swap so i am leaning towards the axles. but i think i am going to buy one of those speed bleeders.
Old Jun 25, 2003 | 04:03 PM
I'm glad I helped.
kpop
19
Nov 30, 2023 08:42 PM
the niz jiz
Mar 22, 2005 03:50 PM
White Lightnin
10
Feb 21, 2003 07:37 AM
EGHatchy
Jul 8, 2002 12:23 PM
eg_nezay
Mar 16, 2002 04:09 PM
