As requested...pics of the PSI racing oil pan
PSI (Power Service Imazu), a Honda tuner of some repute
Obviously the one on the right is more intriguiing; in addition to the increased capacity, a small pump is used to circulate the oil thru an oil cooler and then back into the pan.
Not sure how it does under track conditions, just thought I'd share the pic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">shane, j00 never fail to amaze</TD></TR></TABLE>
You should see what else he can pull out of his *** on command...JDM **** fo shizzle!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len »</TD></TR><TR><TD CLASS="quote">
You should see what else he can pull out of his *** on command...JDM **** fo shizzle!</TD></TR></TABLE>
no thank you
no thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin »</TD></TR><TR><TD CLASS="quote">Alright Shane...non-Japanese speaking person here, please translate. ?They want ~$500 for the pan, then an additional ~$350 for the pump, lines, and cooler??
Austin</TD></TR></TABLE>
I think 50000yen ($425) for the pan, 35000yen ($300) for the pump - u supply the oil cooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs »</TD></TR><TR><TD CLASS="quote">
Yikes...another set of expensive JDM parts...alright, who's the first JDM ***** to post with an install of one of these
</TD></TR></TABLE>Yikes...another set of expensive JDM parts...alright, who's the first JDM ***** to post with an install of one of these
.....coming soon.
</TD></TR></TABLE>.....coming soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
.....coming soon.
I'm sooo gonna poke fun at you when you get it. You're soooo retarded.
While you're at it grab a Mugen Valve Cover.
.....coming soon.
</TD></TR></TABLE>I'm sooo gonna poke fun at you when you get it. You're soooo retarded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w00t! »</TD></TR><TR><TD CLASS="quote">I would rather make it myself...
http://tech.hybridgarage.com/t....html </TD></TR></TABLE>
i posted it in response to the other thread about the Sp00m pan; someone should look at knocking this off instead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT »</TD></TR><TR><TD CLASS="quote">I would much rather have the spoon pan with integrated 5 cap main girdle than anything else i have seen anywhere on themarket.</TD></TR></TABLE>
I thought u don't like anything JDM
Done, and done!
</TD></TR></TABLE>Done, and done!
Done, and done!
LoL...riiight...I want to see the bling.
I'll have some new bling also...we should have a show and tell.
Done, and done!
</TD></TR></TABLE>LoL...riiight...I want to see the bling.
Shane, I was thinking the same thing about running a cooler connected to the pan but thought I might run into problems pumping oil out and back into the pan creating cavitation problems with the stock oil pump. Oh well.
