coilover question
Old Jun 29, 2003 | 01:19 AM
Mr. Choi's Avatar
New User
Default coilover question
https://honda-tech.com/zerothread?id=548721
Old Jun 29, 2003 | 01:44 AM
Mr.Integra's Avatar
Default Re: coilover question (zyg)
I took a look at his coilover. The coilover is so short that it won't rest aginast the stock rubber upper pillow mounts. There is a gap between the pillow mount and the spring itself.
Old Jun 29, 2003 | 01:46 AM
Mr. Choi's Avatar
New User
Default Re: coilover question (Mr.Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Integra &raquo;</TD></TR><TR><TD CLASS="quote">I took a look at his coilover. The coilover is so short that it won't rest aginast the stock rubber upper pillow mounts. There is a gap between the pillow mount and the spring itself.</TD></TR></TABLE>
when the wheel is off the ground.
Old Jun 29, 2003 | 07:48 AM
Cosworth's Avatar
Default Re: coilover question (Chois i-VTEC)
I've never seen such a setup before. The spring should be touching the rubber upper mount for a secure fit (so it's settled always). Why don't you get a shock that goes with your coilover springs? On a stock ITR suspension, you have to compress (the uppermount hat) about 1/2" to get the uppermount nut to come off.
Old Jun 29, 2003 | 11:39 PM
Mr. Choi's Avatar
New User
Default Re: coilover question (Cosworth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cosworth &raquo;</TD></TR><TR><TD CLASS="quote">I've never seen such a setup before. The spring should be touching the rubber upper mount for a secure fit (so it's settled always). Why don't you get a shock that goes with your coilover springs? On a stock ITR suspension, you have to compress (the uppermount hat) about 1/2" to get the uppermount nut to come off. </TD></TR></TABLE>
i dont think you read the post correctly.
the spring is fully uncompressed and has slack when the wheel is off the ground.
and there is no preload on the spring to keep it in place when the wheel is off
the ground or when tehre is absolute no load on the spring. almost all shock
will do the same.
Old Jun 30, 2003 | 12:50 AM
Mario's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chois i-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
will do the same.</TD></TR></TABLE>
Why? Because you are using OEM dampers which are tall. Combine that with short Skunk2 springs, and you'll have a silly little problem on your hand.
Ground Controls also use the shorter Eibach springs because they are cheaper than longer ones.
Here are your options.
1. Get longer springs
2. Add helper springs to your existing Skunk2 springs.
3. Get a REAL coilover/damper assembly with adjustable damper body length (Apex'i N1, Tein RE+, Zeal Function+)
Old Jun 30, 2003 | 02:42 AM
Mr. Choi's Avatar
New User
Default Re: coilover question (Mario)
where can i buy helper springs? and many aftermarket shocks are as tall as original.
im gonna get GC's soon but i will still have the same problem with the skunks,
anyone know where i can get helper springs?
talijan
Apr 21, 2008 04:41 PM
J28S
Oct 4, 2007 02:05 PM
Oregonized
Suspension & Brakes
Jul 23, 2007 08:24 AM
B16b2b
24
Jun 19, 2003 02:04 PM
