oil light blinking
Old Jun 24, 2003 | 01:12 PM
toooslow's Avatar
Default oil light blinking
I was driving and all of a sudden the oil light started to blink. I stopped checked the oil and it was at proper level. I started car and light went away. I kept driving and it turned on again. I let car sit and cool and oil level is still fine, could the sensor be bad?
Old Jun 24, 2003 | 07:40 PM
genetsang's Avatar
Default Re: oil light blinking (whiteinteg95)
change the oil... see if the light still pops on....
Old Jun 24, 2003 | 07:54 PM
Prelude Vtec 23's Avatar
Sounds like your oil pump may be going bad. If your oil level is ok thats likely what may be going on. How many miles do you have on that oil pump?
Old Jun 25, 2003 | 12:04 AM
toooslow's Avatar
just changed oil like 100 miles ago, how much would it cost for a new oil pump? how hard is it to install?
Old Jun 25, 2003 | 01:14 AM
blah13's Avatar
Default Re: (whiteinteg95)
I think mine was about $40, its nothing major. Its quite easy but time consuming bc you have to go through the timing belt, get a manual if you dont have one.
Old Jun 25, 2003 | 03:49 AM
RaIn's Avatar
Last time that happened to me, after checking my oil, about 3 mins later my motor blew.
Old Jul 3, 2003 | 10:56 PM
untitled's Avatar
Default Re: (RaIn)
yup. mine blew too. had the b16 in for 3 days. reved it up to 7k once and came back knocking. unfortunately i didnt get the convinience of a light before hand. it started blinking afterwards. by then it was too late....only to be reborn lsvtec in a month
Old Jul 4, 2003 | 01:15 AM
d0nkeyxPunch's Avatar
Banned
Default Re: (88crx91integra)
I had the same problem on my old b16a motor, but after couple days of that everything worked okay. I have no clue what the problem was but I would like to know.
Old Jul 4, 2003 | 11:43 AM
bossman032's Avatar
Here is my advice to u!!!
I had the same problem.
take out ur oil pan if it has a dent hit it out check up the Pick Up Coil see if its clogged or dirty if not then try change the sensor then if that does not work change the Oil Pump they hardly go bad to tell you the truth... but u never know.. So just in case change it if everything fails.
You wouldn't like a blow motor
Old Jul 4, 2003 | 03:39 PM
976's Avatar
976
New User
Default Re: oil light blinking (bossman032)
Yeah, have it towed to a shop if you cannot do the work yourself.
Old Jul 4, 2003 | 04:40 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">Here is my advice to u!!!
All the above
Plus check the blow off valve in the bottom of the oil pump.
I've read that honda oil pumps rarely go bad, as well, but if they do it's
because of the blow off valve sticking in it's bore. R+R if bad.
Old Jul 4, 2003 | 05:55 PM
altoid's Avatar
Default Re: oil light blinking (4crx4me)
yeah mine kept blinking, i blew my motor...but im coming back i've got a new sohc zc coming in woohoo! Anyone know how severe the damage is? When i turn on my car the engine literally squeels. Anyone know if the crank would be bad or if the pistons are f*cked? I Really just want to replace the rings and bearings and rehone and try again, but i doubt it'll be that easy. just from experience what happened to your internals as a result of destroying an engine due to low oil pressure and/or lack of oil?
Old Jul 4, 2003 | 06:04 PM
4crx4me's Avatar
Default Re: oil light blinking (altoid)
Well, on my Harley Sportster the conn rods share a common crank journal, and it was the conn rod journal bearing that disintegrated.
On my friends MG, it was either a crank bearing or a rod bearing, I can't remember. But, it's usually a bottom end bearing that's the first to let go.
Old Jul 4, 2003 | 07:03 PM
altoid's Avatar
i don't mind bearings, but is there extensive damage to the crank and/or rods? I really want those to be in good shape
Old Jul 4, 2003 | 07:05 PM
untitled's Avatar
the crank will 80/100 will need to be redone. depends on how bad it got.
Old Jul 4, 2003 | 07:12 PM
4crx4me's Avatar
Default Re: oil light blinking (88crx91integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">the crank will 80/100 will need to be redone. depends on how bad it got.</TD></TR></TABLE>
Yes,88crx91int.
It depends on how bad the crank is, you could just have the journals
redone or if it's really bad. Time for a new crank.
At that point, unless your getting it done for free or doing it yourself,
might as well get a whole new motor.
Old Jul 4, 2003 | 08:18 PM
Mohudsolo's Avatar
If the problem started shortly after an oil change, I'd replace the filter with one of a different brand. I've had bad filters that restricted the oil flow. One acted like it was air locked until it was loosened and let some air out of it. Never figured it out but replaced it and everything was fine after that. Another just gave low oil pressure, replaced it and it was back where it should be. That was on a Mazda RX7 that has a pressure guage.
With a motor that had low oil pressure and then knocks, probably rod bearings. Coul easily have damaged the crank journals, possibly damaged the rods by spinning the bearings in them, could also have damage to the main bearings. There could also be damage to the cam bearings, which are the actual head casting, so that can get really expensive.
Old Jul 6, 2003 | 01:11 PM
toooslow's Avatar
as Mohudsolo said about the oil filter, after an oil change thats when i started havng the blinking light problem. That was with mobil 1 filter, i just switched out filter yesterday for a penzoil one. The car was working great with no signs of low oil pressure. The light came on for a second and that was it while i was idleing at a stop light. didnt come on after that though.
Modified by whiteinteg95 at 11:57 PM 7/8/2003
Old Jul 8, 2003 | 02:59 PM
toooslow's Avatar
Old Jul 8, 2003 | 10:59 PM
bossman032's Avatar
is ur problem fixed or what?
Yuta
13
Nov 11, 2016 05:32 AM
IBriaIN
Feb 27, 2011 08:28 PM
e jay one
Jun 1, 2006 05:52 PM
DC_RaceR
Feb 23, 2006 02:00 PM
Cashflo
Apr 25, 2003 07:40 AM
