oil light
Old Feb 22, 2006 | 11:50 AM
DC_RaceR's Avatar
Default oil light
Okay yesterday my oil light came on. but not really bright.. and then it slowly dies out... and i keep driving and it came back on and slowly dies out again?
Is that a sign of a oil pump going bad?
Old Feb 22, 2006 | 11:55 AM
98IntegraLSNonVtec's Avatar
Default Re: oil light (DC_RaceR)
have you checked your oil?
Old Feb 22, 2006 | 12:11 PM
integra3586's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR &raquo;</TD></TR><TR><TD CLASS="quote">Okay yesterday my oil light came on. but not really bright.. and then it slowly dies out... and i keep driving and it came back on and slowly dies out again?
drive as long as you can with you oil light on, its good for the motor
but on a serious note, check your oil its probably low. you might as well change the oil while you at it. i wouldnt drive you car till you at the very least check the oil and get it to the proper level
Old Feb 22, 2006 | 12:13 PM
Perfectionist's Avatar
You could be/have....
Low on oil
Very high or low viscocity oil
Worn engine
Faulty pressure sending unit
Clogged filter
Safest thing to do would be to have the actual oil pressure tested. Could save your motor.
Old Feb 22, 2006 | 01:50 PM
DC_RaceR's Avatar
Default Re: oil light (Perfectionist)
Oil level is fine..
I just did a oil changed last week with new oil pan gasket.
bump
Old Feb 22, 2006 | 02:00 PM
mpham529's Avatar
oil starvation probably.. did u check ur oil level?
Old Feb 22, 2006 | 02:14 PM
DC_RaceR's Avatar
Default Re: oil light (FrostWhiteDC4)
oil level is fine.
Old Feb 22, 2006 | 02:15 PM
mpham529's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR &raquo;</TD></TR><TR><TD CLASS="quote">oil level is fine.
sorry, i didnt scroll down and read the other posts cuz of the gay ads on ht, lol
Old Feb 23, 2006 | 01:33 PM
DC_RaceR's Avatar
bump...
so there no way it's the oil pump?
Old Feb 23, 2006 | 02:00 PM
Deluzional's Avatar
I tried to find the answer for you in archvies, but theres a bunch of reasons that could be causing that light to flicker on and off. try searching, i came up with 280 results.
itzyaboyzeem03
Jul 1, 2016 04:40 PM
IBriaIN
Feb 27, 2011 08:28 PM
acuraman08
Apr 3, 2008 07:04 PM
soon2bdropped
Dec 10, 2006 01:20 PM
Foxcow
10
Dec 16, 2004 08:56 PM
