how the hell do u get the speedometer ring gear off the differential??????????????
Old Jun 23, 2003 | 12:07 PM
hybridb18's Avatar
Default how the hell do u get the speedometer ring gear off the differential??????????????
i just completely rebuilt my transmission with a new diff, and suprise suprise, i didnt put on the speedo gear........!!!!!!!!!!!!!!!!!! i didnt even know the damn thing came off the diff. so, i assume it is threaded on there, is it a reverse thread, or a normal thread??????? also, do i have to take off the bearing to get it off?????? i am so pissed right now
Old Jun 23, 2003 | 04:24 PM
hybridb18's Avatar
Default Re: how the hell do u get the speedometer ring gear off the differential?????????????? (hybridb18)
ttt
Old Jun 23, 2003 | 04:36 PM
Bnjmn's Avatar
drop it off at a machine shop and tell them to pull it unless you have a bearing puller
Old Jun 23, 2003 | 04:40 PM
hybridb18's Avatar
Default Re: how the hell do u get the speedometer ring gear off the differential?????????????? (Bnjmn)
so u pull it off, it isnt threaded on?
Old Jun 23, 2003 | 04:41 PM
hybridb18's Avatar
do you need to take the bearing off to get the speedo gear off?
Old Jun 23, 2003 | 08:17 PM
GruvyTune's Avatar
New User
you heat it with a blow torch till its near red hot then it comes right off!
dont press it off without heating it, you'll break the teeth....
while its still hot, throw it on your new diff. and when it cools it shrinks and it wont come off.
Bob Dole!
Transmission & Drivetrain
Apr 20, 2025 07:42 AM
aut0tek
Sep 10, 2013 09:08 PM
Cleft_Asunder
Aug 16, 2013 03:25 PM
boosted91crx
19
Apr 16, 2009 08:37 PM
HT Chaplain
May 3, 2005 03:26 PM
