am i pulling the cel code right?
Old Jun 23, 2003 | 11:53 AM
turbochic's Avatar
Default am i pulling the cel code right?
Modified by turbochic at 11:15 PM 9/20/2007
Old Jun 23, 2003 | 12:11 PM
Katman's Avatar
Default Re: am i pulling the cel code right? (fmaxturbochic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmaxturbochic &raquo;</TD></TR><TR><TD CLASS="quote">
my question is, is there a different area to pull the codes on a 93 hatch than a 97 civic ex? i wouldnt think so but it didnt work for me, any help would be great.
nope, should be exactly the same.
Make sure when you jump your friends 93 hatch, that you jump the smaller diagnostic plug, while the car is on w/check light being thrown...
Old Jun 23, 2003 | 01:27 PM
turbochic's Avatar
Default Re: am i pulling the cel code right? (Katman)
so the car has to on or just the ignition in the "on" position? yeah i did the smaller one, there are two, one with two wires and one with three wires, i did the one with two wires.
Old Jun 23, 2003 | 02:24 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmaxturbochic &raquo;</TD></TR><TR><TD CLASS="quote">so the car has to on or just the ignition in the "on" position? yeah i did the smaller one, there are two, one with two wires and one with three wires, i did the one with two wires. </TD></TR></TABLE>
the car has to be totally running, with the check light ON, then you jump the service connector and the check light will then start blinking.
Old Jun 23, 2003 | 03:43 PM
turbochic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
the car has to be totally running, with the check light ON, then you jump the service connector and the check light will then start blinking.</TD></TR></TABLE>
wow, i did it with just the ignition in "on" with my car, and it gave me the code,
thank you for your response, i will try what you said. thanks
Old Jun 23, 2003 | 03:55 PM
Katman's Avatar
cool deal..
Old Apr 7, 2006 | 09:00 PM
96accordlxf22b2's Avatar
I cursed out BauleyCivic and got banned
urs would also be a obd-2, which i learned at wirk does not work when jumping with the paper clip i learned that it only works with obd-1 vehicles or older
BI8B
10
Mar 27, 2006 10:48 AM
NoahOneill
Sep 21, 2005 08:46 AM
crxhf19
Jun 4, 2005 11:31 PM
^Sammy]!.
20
Sep 15, 2004 08:30 PM
preluder
May 29, 2003 07:03 PM
