head swap
Old Jun 23, 2003 | 10:51 AM
saggleman's Avatar
Default head swap
i'm swapping out my b16 head this weekend for one that is slightly upgraded... just wondering if there's any advice anyone has on what to do, what not to do, (like drain the oil, change out the timing belt and water pump too, stuff like that) etc. thanks
Old Jun 23, 2003 | 10:58 AM
speedymon's Avatar
Default Re: head swap (saggleman)
New headbolts if you feel like it. I've gotten away with using some w/ 41k on it.
On the headgasket use some copper spray.
Old Jun 23, 2003 | 11:01 AM
saggleman's Avatar
Default Re: head swap (speedymon)
i've got arp headbolts that are going on there, as well as a new headgasket, and a new timing belt, but i hear i should swap out the water pump too, as well as the valve cover gaskets? also, is there any reason to drain the oil? it's almost due for a change, so i might just do it anyways, but i'm just wondering if it's necessary. any kind of problems i can expect to run into?
saemoonyang
17
May 5, 2010 05:56 PM
black0hatch
Feb 13, 2010 06:59 AM
id3379
Mar 22, 2008 09:59 PM
B18C_EJ8
Oct 31, 2004 10:15 AM
Gir
26
Jun 16, 2003 06:09 AM
