97 ITR, in neutral, tranny is locked...
happens some times, where the car comes to a full stop and it does not roll back in neutral because it appears like the LSD diff is lock. Also when it does it's hard to put in gear, any gear. ANy ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR »</TD></TR><TR><TD CLASS="quote">clutch is new
must be some thing else
so?
did this start with the new clutch, before it was installed or just recently (a bit after the clutch was installed)
There are defective parts out there.
must be some thing else</TD></TR></TABLE>
so?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid »</TD></TR><TR><TD CLASS="quote">Bleed the clutch slave and master cylinder.</TD></TR></TABLE>
lol my clutch fluid is at 70,000 miles.. I should change it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 »</TD></TR><TR><TD CLASS="quote">When it is hard to put into gear. Turn the motor off, and see if its hard to get into gear.
If the motor is off and it is easy to get into gear, Your clutch is busted.</TD></TR></TABLE>
yup! thats what happened to me.. turned out to be clutch disc..
perhaps I should add that when the car is cold, the shifting is ok but when it warms up, it gets worse to the point that you can't put any gear in unless it's standing still at full stop. Every gear though makes noise as if it's the LSD...
