HELP i must be the only retard who doesn't know how to check a cel code...
Old Jun 23, 2003 | 05:19 AM
B16EJ's Avatar
Default HELP i must be the only retard who doesn't know how to check a cel code...
Okay, I found the 2 blue plugs covered w/ the green rubber, I got a wire or a paperclip, now which plug do i jump? there is 1 with 3 wires and 1 with 2 wires, but most importantly, this is embarrassing but where the fukc is the blinking light??? I swear I can't find it, don't laugh I know that's sounds messed up but for real I don't know where it is... I got a b16 in my eg coupe and I got a case of the bouncing idle and check engine light someone out there has all the answers to my problems...
Old Jun 23, 2003 | 05:52 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: HELP i must be the only retard who doesn't know how to check a cel code... (B16EG)
the one with the 2 wires. key off, jump them, turn the key on. look at the check engine light. thats what flashes.
Old Jun 23, 2003 | 06:40 AM
B16EJ's Avatar
Thanks alot dude I really appreciate it, I got a cod 7 and 23, I have to wire in the knock sensor 'caus my 94 civic doesn't come ks equipped, that's why it's giving me that, but where do i find the throttle position sensor???
Old Jun 23, 2003 | 06:52 AM
Russ713's Avatar
dAng!
Default Re: (B16EG)
If you mean locating it, it's on the throttle body.
Old Jun 23, 2003 | 06:55 AM
rickbusarow's Avatar
Between the TB and the firewall. The MAP sensor's the one on top.
Old Jun 23, 2003 | 07:13 AM
B16EJ's Avatar
I found it, it's hooked up , besides thath how can i tell wtf is wrong w/ it? also where do i find my knock sensor?
Old Jun 23, 2003 | 08:33 AM
mycvc8u2's Avatar
Default Re: (B16EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16EG &raquo;</TD></TR><TR><TD CLASS="quote">I found it, it's hooked up , besides thath how can i tell wtf is wrong w/ it? also where do i find my knock sensor?</TD></TR></TABLE>
ks is on the back of the block below the intake manifold. two prong plug. good luck
Old Jun 23, 2003 | 09:37 AM
Mr. Badwrench
Default Re: (mycvc8u2)
um the knock sensor should be a 1 pin plug. it is a shielded wire. the connector is green.
Old Jun 24, 2003 | 05:42 AM
B16EJ's Avatar
SWEET!! check engine light is off, but I still got a case of the bouncy idle, now the computer showed a code 7 yesterday, (throttle position sensor) how do I fix this, secondly has anyone ever had a code 7?
Old Jun 25, 2003 | 06:59 AM
B16EJ's Avatar
Everything is fixed!!! B16 runs like a dream, rpms like a rock at 800, even runs quieter, I talked to my buddy who is a honda mechanic and a honda freak, told me how to fix it in two minutes, I felt like a retard then but man, it's pretty sweet when it's all hooked up and everything is working properly, the way it should be. Holla at me if any one needs help with this problem, I don't know if it's as simple as my problem but it's worth a try- all I did was unplug my throttle position sensor (rpms should drop) then adjust your idle plug it back in, I don't remember if idle changed right then, but I shut the car off and started it again and it was perfect. also, my car was warm when I did this, I'm pretty sure most guys with this problem notice that it happens after car warms up or right after you let it rip.
AkureiKami
Jul 28, 2009 01:09 PM
allmotorEG-SI
Jul 20, 2004 09:51 PM
Thagreybomber
Aug 14, 2002 08:15 AM
boyracer
May 9, 2002 05:44 PM
