b16 idle drops
Old Jun 21, 2003 | 12:18 PM
Rob!'s Avatar
Default b16 idle drops
when i turn my lights on or hit my brakes or anything that uses some power....my idle drops down....what an cause this? anyone ever have same problem? bad ground? bad battery or alternator?
Rob
Old Jun 21, 2003 | 02:09 PM
Patch's Avatar
Default Re: b16 idle drops (b16hf)
All of the above. Clean and tighten all of your grounds, clean off your battery posts and terminals. Then, if you have a multimeter, check your battery voltage, and check the voltage with the car running. Running it should be 14-14.5.
Old Jun 21, 2003 | 03:25 PM
RHD_BB4T's Avatar
Default Re: b16 idle drops (CRX PAT)
Yeah, check all that stuff... If not, there should be a electronic load sensor (if I'm not mistaken) that reads the load on the battery and compensates for the drainage of voltage by bumping up the idle... HTH
Dan P.
Coreytownsend
Jun 16, 2018 11:05 AM
wteebo
Honda Civic (2001 - 2005)
Sep 3, 2013 05:25 PM
justint
Jan 20, 2007 08:58 AM
Teglessb18
Jul 8, 2005 01:46 PM
Rob!
Jun 21, 2003 03:04 PM
