battery???
Old Jul 7, 2005 | 08:31 PM
Teglessb18's Avatar
Default battery???
well when I started my car today noticed that when I reved my car a little the rpms would go up and when they came back down it went real low and almost wanted to die and the lights would dim. So I left my car running and disconnected my battery and it still ran which would mean the alternator is working fine (correct me if I am wrong.) So is this an early warning sign that I need a new battery or is this a total different problem? Any help would be great.
Old Jul 7, 2005 | 08:53 PM
solareclipseauto's Avatar
Default Re: battery??? (Teglessb18)
check for a vacuum leak
Old Jul 7, 2005 | 08:55 PM
Teglessb18's Avatar
Default Re: battery??? (solareclipseauto)
dont mean to be dumb but where should I check and what should I use to check it?
Old Jul 7, 2005 | 09:07 PM
gets some carb cleaner and while the car is at idle spray your vacuum lines one at a time and if the car acts as if it wants to die there you go.
Old Jul 7, 2005 | 09:08 PM
Teglessb18's Avatar
I dont think it could be a vaccum leak because my idle is normal its just after i rev it it drops down real low then returns to normal idle i heard (CORRECT ME IF I AM WRONG) that a common problem is your idle will go up and down repetadily if you have a vaccum leak.
Old Jul 7, 2005 | 09:15 PM
that is one problem associated with a vacuum leak, but a vacuum leak can cause other problems depending when the vacuum is hooked up to.
Old Jul 7, 2005 | 10:07 PM
MN_BB4_Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solareclipseauto &raquo;</TD></TR><TR><TD CLASS="quote">check for a vacuum leak</TD></TR></TABLE>
+1
Old Jul 8, 2005 | 09:04 AM
Teglessb18's Avatar
are all the vaccum lines coming out of the IM?
Old Jul 8, 2005 | 09:08 AM
Teglessb18's Avatar
or is there more ???
Old Jul 8, 2005 | 09:34 AM
Master23's Avatar
If the lights dim when the car revved down then it can't be a vauum leak, most likely its your battery or alternator thats about to go. Have you checked your ground connections? Make sure they're snug as well.
Old Jul 8, 2005 | 01:23 PM
Teglessb18's Avatar
Default Re: battery??? (Master23)
ya i checked my alternator by unplugging the battery while the engine was on and it still ran. so i think its the battery. Im gonna get one.
Old Jul 8, 2005 | 01:46 PM
you might wanna check your idle control valve also
Coreytownsend
Jun 16, 2018 11:05 AM
justint
Jan 20, 2007 08:58 AM
ThaCivicAssassin
Nov 30, 2006 01:55 PM
97EXB18C
16
Jul 22, 2004 05:27 AM
Rob!
Jun 21, 2003 03:25 PM
