How much would you pay? I blew my motor!! Please Help
Old Jun 20, 2003 | 04:01 PM
not133t's Avatar
Default How much would you pay? I blew my motor!! Please Help
I have a 1999 Acura Integra GSR with 68k miles on it. I recently blew my motor and put all of this into the car. I would like some suggestions on how much you would honestly pay for the car with BRAND NEW:
BLOCK: http://www.importbuilders.com
Darton Iron Sleeves (closed deck)
Race Coated CP Pistons
Crower Rods
upgraded ARP bolts
Bore, Hone, Hot tank, Deck
Balanced Crank
Polished Crank
All new Bearings & Thrusts
All new seals, and Oil pan Gasket
New VTEC oil pump
New VTEC water pump
LS/VTEC Oil line Kit with all fittings
HEAD: http://www.importbuilders.com
"special" Portflow head porting
valvetrain with Portflow inners
Ti retainers
new valve seals
hot tank
resurfaced
stainless steel black nitrided valves
dowel pins drilled for LS/VTEC
TURBO KIT: http://www.cheapturbo.com
PeakBoost Stainless Steel equal length exhaust manifold made of 304L 8 gauge stainless
Garrett T3/TO4E
Tial 35mm wastegate
PWR 24x6x3.5 Intercooler (2.5" inlet and outlet
Blitz DD BOV
12inch "Slimline" pusher radiator fan
Vortech 12:1 FMU
fully TIG welded complete 3 peice 2.5" charge piping
3inch downpipe with stainless flex section and wastegate dumptube
Stainless oil feed (-4) and oil drain (-10) lines
Weldless oil drain line
All necessary couplings
Strong T-Bolt hose clamps
all necessary bolts and gaskets
BODY/SUSPENCION:
ITR Front
ITR Rear Spoiler
Skunk2 Camber Kit
Skunk2 Coilovers
KYB AGX Adjustables
Old Jun 20, 2003 | 06:41 PM
drumking15's Avatar
eh about 6-7 gs over book value...but then again not many people will give you half of the worth of all you parts in you car so expect like 4-5 over book
Old Jun 20, 2003 | 10:40 PM
not133t's Avatar
Default Re: (drumking15)
thanks for the input!... im suprised no one else has had any
Old Jun 23, 2003 | 09:07 AM
ealltheway's Avatar
ill give you 7 grand for it
Jul 28, 2003 09:45 AM
RyanAutry
Feb 3, 2003 12:15 PM
CivicHb04
Jan 14, 2003 02:23 PM
Jonathan_ED3
Jan 13, 2003 10:58 PM
RyanAutry
Nov 22, 2002 05:55 PM
