Trying to paint my exhaust manifold heatshield - any advice - thanks
Old Jun 20, 2003 | 12:45 PM
B18Redline's Avatar
Default Trying to paint my exhaust manifold heatshield - any advice - thanks
I want to paint my exhaust manifold heat shield. Has anyone done this or have any advice in doing so?
Thanks
Old Jun 20, 2003 | 02:48 PM
johnisenglish's Avatar
Default Re: Trying to paint my exhaust manifold heatshield - any advice - thanks (Redline07)
Sand it down and use high temp paint. Bar-b-que paint works fine.
Do a search on manifold painting, high temp paint, or anything else that applies to the topic, you'll come up with a lot
Old Jun 20, 2003 | 02:56 PM
marltonteg's Avatar
Default Re: Trying to paint my exhaust manifold heatshield - any advice - thanks (johnisenglish)
i sanded the crap outta mine with a wire brush, got rid of 95% of the rust and what not, painted it silver with high temp paint, and its now burnt to a golden color where it gets real hot...if ur gonna paint do it black, guess thats what i get for being ricey...
Old Jun 20, 2003 | 03:21 PM
mospeed's Avatar
Default Re: Trying to paint my exhaust manifold heatshield - any advice - thanks (marltonteg)
**** sanding it, no point
Buy some airlcraft coating stripper spray....
spray it, hose it down and remove any loose stuff.
Find some high temp black BBQ paint and paint it.
Not a close pic, but thats what mine looks like painted.
Old Jun 20, 2003 | 03:28 PM
B18Redline's Avatar
Default Re: Trying to paint my exhaust manifold heatshield - any advice - thanks (mospeed)
Hey, I appreciate everyone's replies...........that bbq black paint looks real nice...where can u get it from? home depot?
thanks
Old Jun 20, 2003 | 06:47 PM
IntEGNYC's Avatar
I didtn bother with aircraft stripper or sanding.
I took a wire brush and brushed all the debris.
Then i took paint thinner and wiped it down clean.
flat black High temp paint was applied in two thin coats. Viola.
the whole process probably took an hour and a half.
close up
Good Luck
Old Jun 20, 2003 | 07:09 PM
mospeed's Avatar
looks good.
However, I'll use ronco's favorite one liner
all i had to do was
"set it and forget it"
Spray the stripper, let it sit for about 30 minutes.
Wash off, and apply about 2-3 coats of paint.
Total work time: about 5 minutes
Total Project time: about an hour with drying.
Old Jun 20, 2003 | 09:39 PM
mantic6t9's Avatar
Default Re: (mospeed)
I stripped it with aircraft paint remover and rubbed it down good with steel wool. Then painted it with duplicolor engine enamel.
Old Jun 21, 2003 | 09:58 AM
baytall79's Avatar
I don't think sanding or stripping is really necessary depending on the starting condition of the sheild. I also used krylon bbq paint, made a huge difference of how my engine bay looks
fragmare
Aug 30, 2012 12:16 PM
EM1 Resto
Paint and Body
Feb 24, 2010 01:03 PM
u n v kenny
Jul 3, 2007 11:10 AM
gapsook
Jun 19, 2004 09:35 AM
BobGnarly
May 31, 2004 10:10 AM
