kaaz powertrain gear oil?
Kazz gear oil is specifically for Kazz lsd's ... i don't know if it would help a normal tranny or not.
Alot of people use stock honda mtf ... works awesome for me.
You can try redline ( i hear it eats synchro's tho).
There are a few other brands... but honda oem is good enuff for my gsr tranny
gear oil is not meant for honda trannys. the way the honda tranny lubricates, it agitates the fluid from underneath and sprayes it up and down over the gears. the gears themselves are not the issue. the tranny itself can run without fluid for a while... it is the bearings, synchros, etc. the gear oils would be great for the gears, however the synchros and bearings would wear out in the tranny and need replacing. stick to MTF. if you have trouble shifting perhaps your clutch master or synchros or technique need work.
MtnCRX
26
May 24, 2005 05:53 AM
hxtasy
Jan 26, 2005 09:45 AM
