Up & Down, Up & Down Idle problem just came back......
Old Jun 18, 2003 | 04:44 AM
SPORT INJECTION's Avatar
Default Up & Down, Up & Down Idle problem just came back......
A few weeks ago I cleaned the screen in the EACV with carb cleaner and the idle ran soo smooth. Yesturday the up & down idle at red lights came back. Since it was the EACV cleaning that helped in the first place, should I just replace the whole thing? Have you guys ever done this? I know this problem can be caused by many different things.
btw... 90 Civic Si
P.S. I replaced my Vehicle Speed Cable last night and that was fun... it actually works now.
and I got new 6.5" speakers in the rear y0
Modified by SPORT INJECTION at 8:27 AM 6/18/2003
Old Jun 18, 2003 | 05:35 AM
1.8Tities's Avatar
Default Re: Up & Down, Up & Down Idle problem just came back...... (SPORT INJECTION)
It could be a bad EACV or you just didn't cleaned it up real good. LOL Try cleaning the TB, recheck the EACV again, and check your spark plug and stuff.. Help this brotha out..
Old Jun 18, 2003 | 05:43 AM
Dirt's Avatar
Default Re: Up & Down, Up & Down Idle problem just came back...... (4thGSi)
RJ knows all.
Old Jun 18, 2003 | 06:55 AM
keithv's Avatar
Default Re: Up & Down, Up & Down Idle problem just came back...... (BrewCityR)
like i said dave, bleed your coolant. its easy to do!
Old Jun 18, 2003 | 02:51 PM
Default Re: Up & Down, Up & Down Idle problem just came back...... (keithv)
Will do. Me and Brewcity were just talking about that. Dirty coolant leads to dirty screen? WHat exactly does the EACV do? thanks keith
Old Jun 18, 2003 | 05:35 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
if all else fails...check you TPS voltage. if its at all under 0.45 V when closed it can cause a surging problem.
Old Jun 19, 2003 | 11:18 AM
tpr's Avatar
tpr
Default Re: Up & Down, Up & Down Idle problem just came back...... (fastcrxsi90)
Also check the warm idle. To do this warm the engine to operating temperature. Disconnect the ECAV. The idle should be ~750 RPM. If not adjust the idle screw which can be found on the top rear of the TB. Screwing In decesases out increases!
Good Luck
Modified by tpr at 12:36 PM 6/19/2003
Old Jun 20, 2003 | 04:20 AM
Default Re: Up & Down, Up & Down Idle problem just came back...... (tpr)
Ha...this morning the car didn't start. (driving a minivan)
Old Jun 20, 2003 | 08:18 AM
1QWKCRX's Avatar
Make sure and check for a code!
It could eb a combination of several things. I had the exact same problem
where after driving the idle would bounce from 700-1500! How annoying!
I had a bad EACV AND a lose idle adj screw.
Old Jun 20, 2003 | 11:20 AM
integ u's Avatar
Default Re: Up & Down, Up & Down Idle problem just came back...... (1QWKCRX)
my car use to do this alot when i first got it (a few weeks back) but now its gone
all u have to do is "air the car out" drive hard for 2 weeks or so......
i have a d15b in my car(for now) so i shift round 5 to 6,000 don't beat on the car but shift at or above 3,680rpm
BTW Zmax engine and fuel cleaner is a good investment. it does help ALOT
it improved the performace in my integra and my 90 civic i just got
liquidx
Oct 5, 2009 06:58 PM
jdm4drSi
Apr 6, 2007 08:19 AM
homeskillet
Jan 13, 2005 05:04 PM
QWKPHKR
Aug 11, 2002 11:35 AM
ASR
Mar 30, 2002 12:04 PM
