High Idle problem
Old Mar 30, 2002 | 03:46 AM
ASR's Avatar
ASR
New User
Default High Idle problem
My r has recently started idling at 1500 rpm, even after warmed up, i'd adjust the idle but before I tried i noticed at a light if I gave it a minute it would drop back to 700 after about 10 seconds, is something sticking, and no the throttle cable isn't too tight.
Old Mar 30, 2002 | 04:23 AM
EagleR's Avatar
Default Re: High Idle problem (ASR)
Just developed the same prob...and I don't know why yet...any ideas?
Old Mar 30, 2002 | 04:37 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
my guess is that is related to the IAC. check your coolant level, then clean the screen on the iac.
Old Mar 30, 2002 | 05:28 AM
ASR's Avatar
ASR
New User
Default Re: High Idle problem (rodney)
Could it be computer related, I put in a hondata and it didn't run so I had to send it back to get reprogramed, then i stuck the old computer back in, I thought amybe it was relearning but its been 2 weeks!
Old Mar 30, 2002 | 11:32 AM
92TypeR's Avatar
FSAE
Default Re: High Idle problem (TypeR1244)
after i put in the skunk computer, the idle began to bounce from about 800-1500rpms consistently. It has been almost 5 months, and it still is doing it. I guess it doesn't bother me anymore, i just got used to it...
Old Mar 30, 2002 | 12:04 PM
JSIR's Avatar
New User
seems to be a common problem when you modify Honda b-series engines, the idle is never the same as stock. I noticed that mods that lighten the rotating assembly make the car idle higher, such as crank pullies, lightened flys, etc.... . I think the IAC eventually is able to get the rpms down but it takes a few seconds after going to a stop. My car does exactly the same thing. My over-bored throttle body may be leading to that also.
jdm4drSi
Apr 6, 2007 08:19 AM
ic89
Oct 16, 2006 05:38 PM
Lmgrcivic
Apr 11, 2005 11:13 PM
TheIntegraGuy
Jan 22, 2004 06:48 PM
chirp2hrd
Oct 13, 2002 01:36 AM
