which turbo setup to use
Old Jun 17, 2003 | 09:35 AM
quickasshatch's Avatar
Default which turbo setup to use
i have a 91 si hatch with a zc and i would like to turbo it. IM curious, im not tryin to spend a ton of money and get a turbo that everyone else has (i.e. greddy turbo kit)
u think i would be ok makin the kit, like using a mitsubishi turbo or saab turbo? somebody help me out!!!!
Old Jun 17, 2003 | 09:38 AM
blackEF's Avatar
Default Re: which turbo setup to use (quickasshatch)
T25 off eclipse, stock dsm BOV, hf manifold, make your own downpipe and oil return, 450cc eclipse injectors, vafc hack, and custom made downpiping. Friend did his for under 600 dollars
Old Jun 17, 2003 | 09:58 AM
under 600? wow! did he get teh turbo off a junker or from mitsubishi?
Old Jun 20, 2003 | 11:14 AM
blackEF's Avatar
Default Re: (quickasshatch)
mistu
Old Jun 20, 2003 | 01:11 PM
4door_gsr_ftw's Avatar
Default Re: which turbo setup to use (blackEF)
What does 'vafc hack' mean?
Old Jun 20, 2003 | 01:58 PM
Brandon Clifton's Avatar
Default Re: which turbo setup to use (Pacman88)
V-AFC hack allows you to modify your fuel so the engine doesn't go lean under boost.
I got my T3 from a Volvo 2-series (B23F) engine. Some Volvos (usually the 7-series) carried Mitsu 14B as well. Subaru 1800 Turbo wagons use the IHI RBH52 turbo, a small, quick spooling rig. Perfect for a 1.5 or 1.6L Honda engine. If you're using an HF manifold and making a custom adaptor plate, any of these will work nicely.
check http://www.homemadeturbo.com for tips
Old Jun 20, 2003 | 03:14 PM
crxguy05sir's Avatar
if you go to http://www.homemadeturbo.com u can find all the info you need.
Old Apr 19, 2004 | 07:30 PM
Curtis2kul's Avatar
Default Re: which turbo setup to use (crxguy05sir)
which do yall think is better that t25 ot t14??????????
paRRRker
Dec 8, 2004 01:50 PM
HXvtec
Feb 1, 2004 10:38 AM
hoya_10fintec
Jun 12, 2003 06:21 AM
mafioso102
Feb 21, 2003 05:37 AM
