CEL is on...help
Old Jun 17, 2003 | 07:21 AM
whatVTEC's Avatar
Default CEL is on...help
I got a CEL on my 93 hatch with a B18b. The code is 16. What is it and how do I fix it.
Old Jun 17, 2003 | 09:14 AM
whatVTEC's Avatar
Default Re: CEL is on...help (whatVTEC)
anyone?
Old Jun 17, 2003 | 11:09 AM
turbochic's Avatar
code 16: fuel injector system defective circuit or unplugged/ defective fuel injector.
as to how to fix it, not too sure. but at least you now know what it is.
Old Jun 17, 2003 | 12:19 PM
whatVTEC's Avatar
Default Re: CEL is on...help (fmaxturbochic)
Thanks, I knew what it was, but I was hoping someone else has had the problem and could tell me what might I have to replace.
Old Jun 17, 2003 | 12:24 PM
turbo*s2k's Avatar
Is that you Daryl?
I would recommend getting a OBD scanner, then disconecting your injectors while the car is running one at a time. Don't disconnect one, then disconnect another. Just check each. Not sure it that makes sense. This should give you an idication of which one is bad if that's the case. The OBD scanner can probably tell you as well without having to unplug the clips from the injectors...
Old Jun 17, 2003 | 12:39 PM
94CivicSi's Avatar
Default Re: CEL is on...help (TurboChrgd_Civic)
Take a long screwdriver. Put the blade end against the injector body and then press your ear against the handle end. If the injector is working, you'll hear a "tick.......tick......tick......tick....." as it sprays. If you don't, that one's not spraying.
I just had my injectors cleaned and rebuilt by RC Engineering. They came back looking like new, working like new and with a full "dyno" plot of their performance before and after service. They did all 4 for under $100 total. When you find the culprit, give them a call!
Old Jun 17, 2003 | 01:19 PM
whatVTEC's Avatar
Default Re: CEL is on...help (94CivicSi)
I'm gonna check it out after work. Hopefully one of the technicians will have some old injectors laying around in case I need one
Old Jun 17, 2003 | 01:31 PM
Perfectionist's Avatar
Code 16 is set when there is a break in the electrical path for the injectors. This could be caused by a poor connection, bad wire, injector coil about to go, or even a brief main relay failure.
Old Jun 17, 2003 | 03:05 PM
whatVTEC's Avatar
Default Re: CEL is on...help (Perfectionist)
I replaced my main relay a few monthes ago. I tried just resetting it, but it stayed off until decel than came on again.
Old Jun 18, 2003 | 06:40 AM
whatVTEC's Avatar
found out the problem..it was code 17 not 16
But it's my tranny that's fu*ked not my VSS.
lsvSwagg
Jan 29, 2013 07:46 AM
dividedas1
Jun 23, 2009 01:46 PM
slow_dx
Feb 11, 2008 08:16 PM
slywfbpsi
Jun 9, 2003 11:07 AM
