Stock airboxes that fit 90civic w/ b16?
Old Jun 14, 2003 | 03:17 PM
NINJASPY's Avatar
Default Stock airboxes that fit 90civic w/ b16?
What stock airboxes fit a 1990 civic w/ a b16?
I currently have a shortram generic and it is wayyy too loud for my liking, and the filter is where the battery used to be(my battery is in trunk now). And its sucking up all the hot air from the radiator/header and the fan is just blowing hot air into the intake...
What stock airboxes fit? itr box might be a a good choice but people want 100+
Old Jun 14, 2003 | 03:30 PM
bryant's Avatar
Default Re: Stock airboxes that fit 90civic w/ b16? (NINJASPY)
Stock civic box will work just fine. I have a stock JDM CR-X SiR box if anyone one wants it also.
Old Jun 14, 2003 | 06:02 PM
mr. carpenter's Avatar
Default Re: Stock airboxes that fit 90civic w/ b16? (Bryant)
i just extended tubing down to where the airbox goes and suck cool air from there
Old Jun 14, 2003 | 07:34 PM
guttedEF's Avatar
Default Re: Stock airboxes that fit 90civic w/ b16? (mr. carpenter)
I've got the stock airbox with a drop-in K&N on mine. I did cut a larger diameter (3") inlet to the box and ran some Home Depot heater hose into the fender like a CAI. Works good for me. What does suck is finding an actual intake hose, for from the box to the TB. I was lucky enough to have gotten an SiR hose with my engine.
I've got a pic if your interested.
Old Jun 14, 2003 | 09:24 PM
CRXSi90's Avatar
Default Re: Stock airboxes that fit 90civic w/ b16? (guttedEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guttedEF &raquo;</TD></TR><TR><TD CLASS="quote">.........What does suck is finding an actual intake hose, for from the box to the TB. I was lucky enough to have gotten an SiR hose with my engine.
I'd like to see the pictures of your setup...I have a stock airbox and think it sure would be benefitial to have some bigger hose in that area. What else could we use if we (I know I sure can't) find a SiR intake hose?
BTW, my setup has a hole cut in the bottom of the resonator to suck up air from under the car, and the other thing that runs right-to-left in the engine bay by the radiator is removed and capped off (with a plastic cup ). I'm beginning to think that that isn't good because the resonator hole in the 'Y' is actually smaller than the other part.
Old Jun 14, 2003 | 10:25 PM
FRESH's Avatar
Default Re: Stock airboxes that fit 90civic w/ b16? (CRXSi90)
Use the 90-93 stock usdm integra one, it will work great that and a k&n panel filter.
Old Jun 14, 2003 | 10:34 PM
CRXSi90's Avatar
Default Re: Stock airboxes that fit 90civic w/ b16? (FRESH)
is modification to anything required, or is the hose 'plug and play'? (stock airbox, stock throttle body)
Old Jun 18, 2003 | 11:17 PM
NINJASPY's Avatar
ttt
Old Jun 19, 2003 | 12:20 AM
EE9's Avatar
EE9
Get a OEM Honda ITR box and pipe from TB to Box... Drop in a Spoon Airfilter...
Old Jun 19, 2003 | 12:47 AM
SEA Hag's Avatar
Default Re: Stock airboxes that fit 90civic w/ b16? (EE9)
Using the stock JDM Integra XSI intake (word on the street is its wider than the US version but I haven't seen them side by side yet so I cant verify this) tube and stock Si box.
Old Jun 19, 2003 | 04:42 AM
bryant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXSi90 &raquo;</TD></TR><TR><TD CLASS="quote">is modification to anything required, or is the hose 'plug and play'? (stock airbox, stock throttle body)</TD></TR></TABLE>
no
ej1love
Oct 28, 2009 01:04 PM
mR. Vash
Nov 10, 2004 04:27 PM
Wes d
Oct 3, 2003 05:17 PM
sinfulDB1
Apr 28, 2003 07:35 PM
AB16A2T
12
Jun 26, 2002 02:21 AM
