Overheating HELP!!!
Old Jun 14, 2003 | 02:43 PM
killeri's Avatar
Default Overheating HELP!!!
I was overheating. I had a leak in my radiator. I replaced it and it is STILL overheating. My fan comes on when I shut off the engine but not while it is running. I am getting flow through my cooling system. Any suggestions?
Old Jun 14, 2003 | 02:54 PM
RHD_BB4T's Avatar
Default Re: Overheating HELP!!! (killeri)
Have you tried swapping out the Thermostat? A lot of times they will stick if you overheat the engine and will have to be replaced. Also, make sure you bleed the cooling system correctly. If you have any kind of air in there, it can give you some funky readings on the temp guage. Anyway, HTH!!!
Dan P.
Old Jun 15, 2003 | 02:25 AM
Elkins911's Avatar
Default Re: Overheating HELP!!! (Dan_P)
did you bleed the system? when does it over heat??? when your driving, stay still, ac on or off.... lets not be to useless when posting a new thread.
Old Jun 15, 2003 | 01:19 PM
killeri's Avatar
It overheats while sitting still, driving, ac, etc. I didn't know it needed to be bled, I just have a Chiltons, It didn't bother to tell me that and I've never replaced a radiator. Would that prevent the fan from coming on?
Old Jun 15, 2003 | 01:35 PM
RHD_BB4T's Avatar
Yeah, you've got to bleed the system after you're done doing the radiator swap. Here's a link that might help:
https://honda-tech.com/zerothread?id=395245
HTH!
Dan P.
Gelignite
Jul 13, 2015 04:22 PM
pesater
Jan 1, 2009 04:12 AM
PeakBoostSi
Jul 7, 2007 03:27 PM
sherms48
Apr 9, 2007 01:35 AM
