can i convert my obd2 distributor to obd 1??(searched)
Old Jun 13, 2003 | 10:25 AM
mycvc8u2's Avatar
Default can i convert my obd2 distributor to obd 1??(searched)
car=93 civic cx
swap=complete d16y8
question=i have a p28 ecu but am having a real hard time getting a obd1 sohc vtec dizzy. can i rewire my obd2 dizzy that came with my swap to work with obd1?? if so what do i need to do. thanks
Old Jun 13, 2003 | 11:33 AM
Damon's Avatar
Default Re: can i convert my obd2 distributor to obd 1??(searched) (mycvc8u2)
dizzy? never heard that slang for ECU before.
(sorry for the lack of help here, I am an OBD2 dork.)
Old Jun 13, 2003 | 11:43 AM
vladd's Avatar
Default Re: can i convert my obd2 distributor to obd 1??(searched) (Damon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon &raquo;</TD></TR><TR><TD CLASS="quote">dizzy? never heard that slang for ECU before.
(sorry for the lack of help here, I am an OBD2 dork.)</TD></TR></TABLE>
dizzy=distributor
anyways, i'm pretty sure you can.
Old Jun 13, 2003 | 11:59 AM
andrew dc's Avatar
Default Re: can i convert my obd2 distributor to obd 1??(searched) (civicdxtyper)
cut the plugs on both dizzys.. take the obd2 dizzy and match with obd1 plugs... you are set!
Old Jun 13, 2003 | 04:32 PM
dogpile5's Avatar
25 Year Member
Default Re: can i convert my obd2 distributor to obd 1??(searched) (CRX25)
if you are patient, you could also just pull the pins out and re-pin into the obd1 plugs. will work just fine.
Old Jun 13, 2003 | 04:38 PM
flat-blk-HB's Avatar
Default Re: can i convert my obd2 distributor to obd 1??(searched) (dogpile5)
There is a wire missing on the OBD2 dizzy. You have to add it to make it work. I did this on my 92 DX with my 99 D16Y8. I rewired the the OBD1 plugs and added the one wire.
Old Jun 14, 2003 | 05:02 PM
mycvc8u2's Avatar
Default Re: can i convert my obd2 distributor to obd 1??(searched) (flat-blk-HB)
thanks guys-i am gonna try this tomorrow.
baldeagle432
Sep 18, 2009 09:53 PM
3k9civic
Jan 10, 2006 04:25 PM
98JDM_Type_R
Aug 19, 2004 01:51 PM
mycvc8u2
Jun 25, 2003 12:34 PM
Doodoo
Jan 23, 2003 02:33 PM
