can i convert my obd2 distributor to obd 1??(searched)
car=93 civic cx
swap=complete d16y8
question=i have a p28 ecu but am having a real hard time getting a obd1 sohc vtec dizzy. can i rewire my obd2 dizzy that came with my swap to work with obd1?? if so what do i need to do. thanks
swap=complete d16y8
Re: can i convert my obd2 distributor to obd 1??(searched) (Damon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon »</TD></TR><TR><TD CLASS="quote">dizzy? never heard that slang for ECU before.
(sorry for the lack of help here, I am an OBD2 dork.)</TD></TR></TABLE>
dizzy=distributor
anyways, i'm pretty sure you can.
dizzy=distributor
Re: can i convert my obd2 distributor to obd 1??(searched) (civicdxtyper)
cut the plugs on both dizzys.. take the obd2 dizzy and match with obd1 plugs... you are set!
Re: can i convert my obd2 distributor to obd 1??(searched) (CRX25)
if you are patient, you could also just pull the pins out and re-pin into the obd1 plugs. will work just fine.
Re: can i convert my obd2 distributor to obd 1??(searched) (dogpile5)
There is a wire missing on the OBD2 dizzy. You have to add it to make it work. I did this on my 92 DX with my 99 D16Y8. I rewired the the OBD1 plugs and added the one wire.
3k9civic
01-10-2006 04:25 PM
mycvc8u2
06-25-2003 12:34 PM
