Help with stock intake connection..
Old Jun 13, 2003 | 03:26 AM
KillerB's Avatar
Default Help with stock intake connection..
You all see the two red circle, what are they suppose to be connected with? can't find any connection for it.
Here's more view of the engine.
thanks.
Old Jun 13, 2003 | 03:33 AM
Art Vandeleigh's Avatar
Default Re: Help with stock intake connection.. (KillerB)
here let me help you out...
Sorry, but im pretty tired right now, but I dont see any red circles??? What are you talking about??
Old Jun 13, 2003 | 03:43 AM
civicsirplus's Avatar
it connects to the hose to the right of that left circle. just disconnect the hose from that clamp and then reconnect the two ends to the ends of the metal pipe bridge. Water passes thru this pipe.
Old Jun 13, 2003 | 03:48 AM
KillerB's Avatar
Default Re: Help with stock intake connection.. (civicsirplus)
anybody got a close up pic of ITR engine with stock intake showing the connections?. I search for engine pic but can't find anything helpful.
Old Jun 13, 2003 | 03:50 AM
dood - it doesn't even have to be a stock ITR. Just bowl into a car yard and look at the stock setup of any B series engine and its the same!! Here ya go:
Modified by civicsirplus at 1:04 PM 6/13/2003
Modified by civicsirplus at 1:05 PM 6/13/2003
Old Jun 13, 2003 | 04:25 AM
Asahi's Avatar
Someone had an aftermarket intake on your car previously and bypassed the metal piece for the coolant line.
Old Jun 13, 2003 | 05:04 AM
KillerB's Avatar
Default Re: Help with stock intake connection.. (Asahi)
Yeah, I took out the AEM and put stock intake back. Now I can't remember where the two line connects.
Old Jun 13, 2003 | 05:06 AM
Asahi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerB &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I took out the AEM and put stock intake back. Now I can't remember where the two line connects.</TD></TR></TABLE>
The 2 lines are already connected and you will need the original hoses to hook it back up to the metal piece instead of the way you have it run now.
Old Jun 13, 2003 | 05:12 AM
KillerB's Avatar
thanks.
Old Jun 13, 2003 | 01:43 PM
KillerB's Avatar
Default Re: (civicsirplus)
Civicsirplus, nice close up of the engine thanks.
Old Jun 13, 2003 | 01:46 PM
jdmspoonitr's Avatar
Default Re: (KillerB)
Leave it as is. the aem comes with a hose so you don't have to use the metal piece. there is no harm in having the rubber one, so I would just leave it and save the trouble.
Old Jun 13, 2003 | 05:44 PM
KillerB's Avatar
Default Re: (jdmspoonitr)
Before
After
Stock intake feel much better at low end...
Modified by KillerB at 10:00 PM 6/13/2003
Lexxi_TegK24
Aug 1, 2014 11:37 AM
ludekid4323
Mar 17, 2007 12:56 PM
mechanicnoob
12
Sep 4, 2006 08:17 PM
P95
Aug 3, 2005 06:00 PM
EG6AAARRR!!!
Aug 23, 2004 01:09 PM
