rebuilding head.. need suggestions
Old Jun 11, 2003 | 12:10 PM
1hotintegra's Avatar
Default rebuilding head.. need suggestions
im rebuilding my head in about a week and this is what im doin so far...skunk 2 stage 2 cams ($640) skunk2 valve springs($212) skunk 2 ti retainers($127), small port and polish job. am i forgeting anything??? and also this is my daily driver which im just building cuz i bent valves by over reving it, so what woudl be a disadvantave of goin with a more intense p&p job than a light one?? also im just using stock valves... this is ok right?? and should i just replace the ones i bent or should i just do all of em.. moneys kinda tight so i cant afford many extras so could i could get away with just reusing the good valves ???
Old Jun 11, 2003 | 12:29 PM
zc911's Avatar
Default Re: rebuilding head.. need suggestions (1hotintegra)
Find some used valves, they would be a cheap alternative to new ones
ITR vavles are worth a little HP, and flow better than b16/GSr ones
Don't forget Cam gears
Old Jun 11, 2003 | 12:50 PM
Default Re: rebuilding head.. need suggestions (zc911)
well... i cant afford differnt valves so coudl i get away with using the ones that arnt bent in my head now?? i think i am gunna get cam gears now but could i wait a few weeks they slip right on right
Old Jun 11, 2003 | 02:06 PM
navin's Avatar
what abuot the valves u bent - did u replace those..??
porting the head allowes more air to flow, and which also lowers your compression ratio..
Old Jun 11, 2003 | 04:58 PM
Default Re: rebuilding head.. need suggestions (navin)
well i wana replace the ones i bent and reuse the ones that arnt bent
Old Jun 13, 2003 | 08:31 AM
ttt
Old Jun 13, 2003 | 12:28 PM
Propulsion's Avatar
"porting the head allowes more air to flow, and which also lowers your compression ratio.."
huh? is this a typo? if more air flows into the cylinder before each compression stroke, wouldn't you have a higher compression?
Old Jun 13, 2003 | 01:44 PM
NSX Bob's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by navin &raquo;</TD></TR><TR><TD CLASS="quote">porting the head allowes more air to flow, and which also lowers your compression ratio..</TD></TR></TABLE>
? Having large primary lobed cams can reduce compression (see static v. dynamic compression), but how do you propose a P&P job lowers compression? To answer the original question in this post, make sure your lma's are appropriate for the set-up.
Old Jun 13, 2003 | 02:04 PM
Default Re: rebuilding head.. need suggestions (Type R Bob)
stock gsr lma's with skunk2 stage1 cams is this alright?
DeLaTorre EG
May 29, 2011 09:41 AM
remoer
Dec 6, 2007 06:22 AM
1hotintegra
Jun 13, 2003 04:46 PM
1hotintegra
Jun 12, 2003 08:14 PM
advanracing62
Oct 3, 2002 09:43 AM
