Lose H.P when useing an Bypass valve
Old Jun 10, 2003 | 01:38 PM
typeR 507's Avatar
Default Lose H.P when useing an Bypass valve
hey i was planing on put an AEM bypass valve on my AEM cold air intake . One of my boys told me that i would lose H.P if i would put .im not sure what ya think is it ture ot not what ya think ?
Old Jun 10, 2003 | 01:41 PM
Chris N's Avatar
Default Re: Lose H.P when useing an Bypass valve (TypeR507)
I think you shoudn't use the bypass valve at all.
It is more likely to get sucked up your intake than it is to help if you are sucking only water.
Old Jun 10, 2003 | 01:46 PM
pyromaster's Avatar
actually they fixed it where it won't suck the foam now but you can join the club of having the POS break in half like the rest of us did
https://honda-tech.com/zerothread?id=514199
jeff, who just slapped the filter where the bypass valve goes and has a short ram ghetto style
Old Jun 10, 2003 | 02:17 PM
jond's Avatar
Default Re: Lose H.P when useing an Bypass valve (pyromaster)
I would consider just drilling a small hole in the top of the intake and put ductape over it. Remove when it rains hard.
Old Jun 10, 2003 | 02:50 PM
typeR 507's Avatar
so should i put use it or not
Old Jun 10, 2003 | 02:51 PM
typeR 507's Avatar
so should i use it or not ?
Old Jun 10, 2003 | 02:56 PM
Big Phat R's Avatar
Why don't you wait for the new version to come out??
Old Jun 10, 2003 | 03:00 PM
py1188's Avatar
Default Re: Lose H.P when useing an Bypass valve (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you wait for the new version to come out??
I thought they said they weren't coming out with a V2 for the ITR??
Old Jun 10, 2003 | 03:14 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
they arent. couldnt get it to make any more power than V1.
Old Jun 11, 2003 | 06:15 PM
typeR 507's Avatar
mmmmmmmmmmmmmmm
Old Jun 11, 2003 | 06:36 PM
georgiajdm's Avatar
Default Re: Lose H.P when useing an Bypass valve (jond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">I would consider just drilling a small hole in the top of the intake and put ductape over it. Remove when it rains hard.
exactly... i thought the bypass valves got recalled cause numerous people reported the foam breather getting dislodged and getting sucked in the throttle body.
Anyways the bypass sucks in air from the engine bay and not from where the filter sits. Principal: When you suck through a straw it draws liquid from the bottom, when you punch a hole in the straw you can no longer suck up liquid cause the suction is now drawn from the hole in the straw, same principal preventing hydrolock and proving air is drawn in from the engine bay and not from the filter.
Old Jun 11, 2003 | 09:13 PM
kitkatR's Avatar
Default Re: Lose H.P when useing an Bypass valve (georgiajdm)
Stock with K&N owns, plus it makes more power (from what I have seen on my car and others) just a thought
Old Jun 11, 2003 | 09:46 PM
kepani's Avatar
Default Re: Lose H.P when useing an Bypass valve (kitkatR)
what's up kitkatR!?
i would also agree. i used to have an aem cold air intake and since have gone back to the stock airbox. better low end response and more peace of mind. plus, much easier to replace/clean the filter.
Old Jun 11, 2003 | 11:11 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyromaster &raquo;</TD></TR><TR><TD CLASS="quote">actually they fixed it where it won't suck the foam now but you can join the club of having the POS break in half like the rest of us did
jeff, who just slapped the filter where the bypass valve goes and has a short ram ghetto style </TD></TR></TABLE>
&lt; broke as well.
I just some rubber hosing and clamped my two pieces togther after I took off my by-pass valve. I was worried about sucking up water too. Trust me unless you are an idiot it shouldn't be a problem. If I were you I'd just slap a K&N in the stock air box and be done with it.
Old Jun 11, 2003 | 11:33 PM
SoCal ITR's Avatar
I did the same thing.
Old Jun 12, 2003 | 07:06 AM
onyx00's Avatar
Default Re: Lose H.P when useing an Bypass valve (SoCal ITR)
Or you could waste money on the Comptech shitbox. j/k It's nice but if I have to do it again I would throw in a K&N as well. Maybe modify the stock air box to flow a little more freely.
Spazbaboon
Dec 27, 2006 03:09 PM
SpeedMachine
Jun 8, 2005 06:02 PM
CRLude97
Jan 9, 2004 01:41 AM
HONDAGIRLL23
Aug 12, 2002 12:58 PM
B18Redline
May 3, 2002 01:15 PM
