Turbo GSR Question
Old Jun 9, 2003 | 02:13 PM
BabyBlueGSRT's Avatar
Default Turbo GSR Question
Hey. I designed my urbo kit with a Td05 turbo and with 6 pounds of boost I melted 1 piston and now i want to upgrade. Im going to not sleeve the block and just run and 18 g turbo with 9 to 1 static compression pistons and crowler rods to handle the boost which is 20 pounds. What do you guys think and what have you done for boost thats that high.
Old Jun 9, 2003 | 02:15 PM
venom's Avatar
Default Re: Turbo GSR Question (BabyBlueGSRT)
maybe try asking your question here
Old Jun 9, 2003 | 02:17 PM
CNSK's Avatar
Default Re: Turbo GSR Question (venom)
try "force induction" category, you get better response maybe...
Old Jun 9, 2003 | 02:21 PM
Br1t1shguy's Avatar
Default Re: Turbo GSR Question (DrMartin)
and maybe you should try tuning you're car on a dyno. No one should melt a piston at 9lbs of boost....
Old Jun 9, 2003 | 03:23 PM
neo1z's Avatar
Default Re: Turbo GSR Question (Br1t1shguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Br1t1shguy &raquo;</TD></TR><TR><TD CLASS="quote">and maybe you should try tuning you're car on a dyno. No one should melt a piston at 9lbs of boost....</TD></TR></TABLE>
Yea, you have to be pretty good to melt a piston at that low of boost.
Old Jun 9, 2003 | 03:27 PM
Dorikamu's Avatar
20 psi..
it's gonna be ugly.. just make sure you have the cash ready when it blows.
Old Jun 9, 2003 | 05:06 PM
n0 iNTegRiTY's Avatar
Default Re: Turbo GSR Question (chusai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chusai &raquo;</TD></TR><TR><TD CLASS="quote">20 psi..
it's gonna be ugly.. just make sure you have the cash ready when it blows.</TD></TR></TABLE>
Agreed.
What else have you done to the engine? Cuz it probably wont hold up long with 20 psi on a near stock engine. Unless someone can prove me wrong.
Old Jun 10, 2003 | 02:23 PM
Default Re: Turbo GSR Question (RAF LTD. 2)
complete engine managment it wasnt intercooler. i think thats why it is now
Old Jun 10, 2003 | 02:31 PM
Ramocheese's Avatar
If you keep your a/f ratio ok, with good rods and pistons you should be able to handle 20psi, although sleeving the block will definitely give you some insurance. People are making good power on stock sleeves, but as soon as you detonate once, you'll crack one.
No flame intended, but if you blew up a piston on 9psi, you need to work out your fuel system first. You need a hondata or an AEM EMS. Don't go the afc hack route, it won't be as reliable.
Old Jun 10, 2003 | 02:32 PM
Dorikamu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BabyBlueGSRT &raquo;</TD></TR><TR><TD CLASS="quote">complete engine managment it wasnt intercooler. i think thats why it is now </TD></TR></TABLE>
I didn't understand what you wrote at all????
Old Jun 10, 2003 | 03:50 PM
PM-Performance's Avatar
yea id work on the managment for sure , but i have seen stock sleeves got past 450 whp already , just make sure its tuned right or you will be rebuilding twice
Old Jun 10, 2003 | 06:05 PM
one more chance's Avatar
Default Re: Turbo GSR Question (itr206)
blowing piston number 1 on a high compression engine is not difficult at all. especially if it wasn't intercooled! (what were u thinking!!??) more then likely, the car wasn't tuned correctly!! when the car is running too lean, then the temperature in the combustion chambers get to crazy levels. my advice to you is the resleeve the cylinder and grab a set of forged pistons, intercool it, tune it properly with a stand-alone ecu, and then ur set to run 20psi!
jdjustme
Mar 9, 2007 01:05 PM
teddy_dc2
Aug 6, 2006 07:10 AM
Toroke
Apr 6, 2006 04:02 PM
2000vsm
Sep 12, 2003 07:36 PM
99SilverEx
Jul 6, 2002 11:28 AM
