Compression test results -=o(
We did a compression test on a 94 SI hatch the othe day and yeilded these results: 130-125-125-160 (in order of 4-3-2-1). We then added a capful of oil in each cylinder and yielded these results (165-170-170-165). Rings were probably shot after boosting 10-12 psi for a month or so. My question is: Has anyone tried that RESTORE engine lubricant? Is it only a temporary fix to the problem or do the rings HAVE to be replaced? Thanks.
http://www.restoreusa.com/index.html
B16 pistons yield a higher compression ration then CTR pistons in a B18C1.
Here's a website to a compression calculator. You will notice that JDM B16 pistons yield the higher compression ratio.
http://www.c-speedracing.com/h...c.php
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I wanna be Steve! »</TD></TR><TR><TD CLASS="quote">B16 pistons yield a higher compression ration then CTR pistons in a B18C1.
mkay
mkay
wheres the imformation police........cuz hes giving out false information.
closest you can come to boosting compression by 1 point with oem pistons in a d16z6 would be with d16a6 pistons which should give you about 10.8:1. Use a turbo headgasket to get it down from there....otherwise use the z6 pistons.
Using that calculator, I came up with a 11.9:1 compression ratio with JDM B16A pistons, and a 12.4:1 compression ratio with JDM B16B pistons.
Maybe you should try using the calculator again before you spout bad info.
LOL?
LOL?
read carefully... the guy asked:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoW3l2BaN »</TD></TR><TR><TD CLASS="quote">thanks for the quick reply guys. New rigns i guess it is? what oem honda pistons will bump up the compression a point or so.? b16 ?</TD></TR></TABLE>
