which starter for 91 CRX-B17/S1 (or JDM S1) ?
Old Jul 18, 2001 | 11:29 AM
wignersfriend's Avatar
New User
Default which starter for 91 CRX-B17/S1 (or JDM S1) ?
Me: 91 CRX Si w/ B17 and an S1 tranny. The tranny doesn't have an place for a rear mount bracket. It also has two additional hose fittings next to the speedo cable outlet. Would this be an indication of it being JDM (what I was told) or a 90 Integra (what is scribbled on it)? I tried to use a 93 Integra GSR starter. All it does is make a very loud tapping when I try to start it. It sounds to me like the teeth aren't engaging correctly. I appreciate anyone's input.
Old Jul 18, 2001 | 11:40 AM
raene's Avatar
Default Re: which starter for 91 CRX-B17/S1 (or JDM S1) ? (wignersfriend)
The two little extra oil fittings are actually for an external oil cooler, or so I'm told. I'm not sure of any particular way to tell if it's JDM or not, actually. There IS a USDM S1 transmission, however. I would think you would use the starter to match the flywheel, so if you could find a match for the flywheel, you're probably all set...
Old Jul 18, 2001 | 12:01 PM
New User
Default flywheel?
what's a flywheel?
actually, I thought the flywheels were all the same. Mine's from a 1st gen B16. I still don't know what starter would match that.
killerpenguin21
Jul 13, 2007 02:00 PM
leboeuf45
May 13, 2004 07:48 AM
EFPROJECT
Apr 27, 2004 10:23 AM
92lsr
Jan 17, 2004 09:27 AM
HidPerf
Jul 3, 2002 04:04 PM
