shift boot install
Old Jun 7, 2003 | 03:38 PM
redex94's Avatar
Default shift boot install
anyone know how to install a eg shiftboot , pictures would be appreciated thanks.
Old Jun 7, 2003 | 03:46 PM
-Gambit-'s Avatar
Default Re: shift boot install (redex94)
take off your shift ****, then unscrew your center console then you will see a few screws holding on your shift boot. Its a real easy install. It should take you about 7 minutes.
Old Jun 7, 2003 | 04:16 PM
4DRPIMPIN's Avatar
if it's a ctr boot you are goin to have to use the bracket from your stock boot....
Old Apr 8, 2004 | 06:22 AM
integrakilla's Avatar
Default Re: (4DRPIMPIN)
where are the bolts located for the center console
Old Apr 8, 2004 | 06:27 AM
scratchy's Avatar
Default Re: (integrakilla)
ohh my god man do you know how to tie your shoes or undo a belt?????
Old Apr 8, 2004 | 06:38 AM
civic97b18csi's Avatar
Default Re: (scratchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchy &raquo;</TD></TR><TR><TD CLASS="quote">ohh my god man do you know how to tie your shoes or undo a belt?????</TD></TR></TABLE>
Old Apr 8, 2004 | 06:44 AM
Jaysun's Avatar
Default Re: (civic97b18csi)
https://honda-tech.com/zerothread?id=446771
Old Apr 8, 2004 | 07:00 AM
opi's Avatar
opi
Default Re: (QuikJaysun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuikJaysun &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=446771</TD></TR></TABLE>
Good link/info
Old Apr 8, 2004 | 09:03 AM
Skip01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrakilla &raquo;</TD></TR><TR><TD CLASS="quote">where are the bolts located for the center console</TD></TR></TABLE>
Theres two on each side on the bottom by the cupholders.And two under a panel right under the e-brake when its all the way down.Then it should come out and like someone said there are about 6-7 screws that are holding the boot on.Its fairly staright forward.Good Luck.
-Championship-
Jul 2, 2006 09:37 PM
mrjaydem
Sep 20, 2005 06:50 PM
crosswrench
Apr 27, 2004 05:40 PM
deuceap610
Mar 1, 2004 07:25 AM
manick
Jul 2, 2002 09:03 PM
