shift boot install
Re: shift boot install (redex94)
take off your shift ****, then unscrew your center console then you will see a few screws holding on your shift boot. Its a real easy install. It should take you about 7 minutes.
Re: (scratchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchy »</TD></TR><TR><TD CLASS="quote">ohh my god man do you know how to tie your shoes or undo a belt?????</TD></TR></TABLE>
Re: (QuikJaysun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuikJaysun »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=446771</TD></TR></TABLE>
Good link/info
Good link/info
Re: (integrakilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrakilla »</TD></TR><TR><TD CLASS="quote">where are the bolts located for the center console</TD></TR></TABLE>
Theres two on each side on the bottom by the cupholders.And two under a panel right under the e-brake when its all the way down.Then it should come out and like someone said there are about 6-7 screws that are holding the boot on.Its fairly staright forward.Good Luck.
